1937 John Deere A
treasuremill
07-05-2006 18:53:31
Hey guys got a question.I just got a 1937 John Deere A running after sitting for 20 years.Did a rebuilt carb.,sealed gas tank, new points,and all new fluids..Got it running but it has little power and backfires threw the air breather.Any ideas where to go to next?Thanks for all your advice-it is very much appreciated.Mike
1936
07-06-2006 17:49:11
 Re: 1937 John Deere A in reply to treasuremill, 07-05-2006 18:53:31
Well, before all of the high lift gingus pins are rotated you could do a few simple thing that an old timer did to resolve the back firing on my A with a mag. The mag gasket was bad and water rusted the coil and condenser was weak. Cleaned the mag body replaced the coil, condenser and points and put a little chain saw oil into the gas to free up any sticking values. Runs and will not pull it"s self replace the plugs. Always go for the blue spark off the mag coil with a grounded screw driver never yellow.
Mike M
07-05-2006 19:45:16
In addition to all the other suggestions I'd also check out the LEFT HAND cam bearing for being shot. I have found A's notorius for this problem often overlooked and easy to check. Just pull the bearing cap off ,2 bolts behind the upper left of the flywheel on the main case. It's a timken bearing and if shot you will easy tell as the race in the cover will not be smooth anymore. I have replaced many LEFTS and not the rights as the right is alot harder to get to and from experience with tearing down parts tractors the LEFT is usually shot and the RIGHT not too bad.
johns48b
07-05-2006 19:25:34
your timing is off. there maybe some other methods that others will suggest on how to time your tractor. i timed my 48 b the way a jd mechanic of 55 years (in 1999, and still working) told me. loosen the mag, turn it all the way to the left and snug down just tight enough to where you can still move it by hand and set the holes on the flywheel level with the ground. turn the mag until you hear it trip and tighten it down. the spot where you set the flywheel on that early of a model tractor may be different, but you get the idea. john t or fit will probably tell you different and better. also you may need to clean the air intake system completely out including the air filter system and refill the cup with 30 weight oil.
DSK
07-05-2006 19:24:43
Reminds me of the first old A I worked on years ago. That one had stuck valves & rings from setting for years. Take off the tappet cover and spray penetrating oil on the valve stems while working the valves back and forth manually or with the tractor running. When the tractor is running you should see a constant drip of oil coming from the tappet oiler pipe. Make sure the drip holes in the tappet oiler trough above the exhaust valves are open also. If it has stuck rings, they should loosen up after a couple hours of running time. These are the simple things to try first, if things don't improve with them, then you may have to tear it down for a valve job & re-ringing or more.
John T
07-05-2006 19:23:16
You might wanna take a look at the valve lash settings plus maybe an intake valve is sticking some??? If the valves are sticking and/or the rings are carboned up n stuck if it were mine I would drian n flush the crankcase then re fill with a good detergent 10W 30 oil mixed in with some Rislone and Auto Tranny Fluid and run her hard n hot for some time then change oil again back to oil and some Marvel Mystery Top Oil lube n see how she does then.
John T
