"Actually, if I had a tractor that had a problem that was draining current from the battery, I would fix the problem rather then use one of those disconnects which could cause a problem itself." Hear! Hear! How the heck did those systems function for the first 50-60 years? The starter power is tranferred by a mechanical switch operated by your foot, and the only engine side B+ wire for lights and siren comes up from the starter to the dash. Put in a nice self-resetting circuit breaker ($15.00 from Deere) like they use on the lawn tractors, or a big fuse, OR install fresh wiring and heat shrink boot the terminals. Old does not mean that they have to leak juice and drain batteries. New bigger batteries are used to cure weak engines and worn out starter brushes, high energy ignitions are used to cure low compression, leaky carburetor throttle plates, and worn bores, 8 volt batteries are used to cure EVERYTHING on a 6 volt system, 12 volt conversions are used to cure a 6 volt system when the 8 volt battery trick fails, a 10SI alternator is used to cure everything that is wrong with a 12 volt generator/regulator system, 24 volt starters are used to cure tired pony motors, and as soon as anyone gets a 4010 or early 4020, they take the 24 volt system off and put a 12 volt system on it. Just fix! I believe you'll be so much happier with your machine. Frank
