4010 draft control seal
RFox
07-05-2006 12:49:10
My 4010 just recently start steadily leaking hyd fluid from the draft control left side. I assume it is the seal that goes in the draft control rod bushing? How hard is it to replace this thing,I heard the part is only $10, but can I replace just one side, and easily? Thanks!
Glen in TX
07-05-2006 13:40:02
 The right link to Boling in reply to RFox, 07-05-2006 12:49:10
Sorry, put in wrong link to Boling below. Try this one. Also JD supplies shim washers for the wishbone casting and use those if casting moves side to side a lot. That and worn holes will knock the seals and bushings out in again in no time.
Glen in TX
07-05-2006 13:32:48
 Re: 4010 draft control seal in reply to RFox, 07-05-2006 12:49:10
Get the needed parts from JD or aftermarket ones. I've used both with good results but like said putting a worn shaft back in with worn bushings is just a waste of time and cost of seals. Check with your JD service manager and their JD service or tech manual for a 4010 should give wear specs to measure for the bushings and load control shaft. JD made bushings for some models with oversize ID if hole in trans casting is worn but they may or may not still be available. Sometimes the bushings are harder to get out but if worn and you don't replace them expect to be doing the job again and again. If holes, bushings or pins are worn on the rest of wish bone and 3 point hitch and you don't fix those also then it will knock the seals back out again in no time. Fix it all right if want it to last.
Can view parts at http://jdparts.deere.com
G/MAN
07-05-2006 13:30:06
The standard Deere parts will work just fine, but your local dealer might also stock the aftermarket units. More than likely the shaft will be shot also, as has been mentioned, and if you don't also replace the bushings in the drawbar support frame, you'll be wasting your time also. The bushings also go in in a particular manner, as the i.d.s are slightly tapered to allow the shaft to flex for the load and depth system to function correctly. When removing the pin securing the front of the drawbar frame, don't worry about the roll pin that retains it. Drive the big pin out and simply shear the roll pin off as you're driving it out.
DSK
07-05-2006 13:22:06
You will need to pull the load control shaft out for inspection any way, so you might as well replace both sides. Check the shaft itself for wear where it contacts the seals and bushings, the bushings in the case may have to be replaced also. There is a seal set sold by an aftermarket supplier thats supposed to last longer than the ones from Deere, but I've had no experience with them, maybe someone else has some input on these. Don't put it together with new seals and a worn shaft or bushings, it will leak again within a few hours.
Mike M
07-05-2006 13:21:17
Not too bad. Drain all the oil out and do both at the same time. I'd also put in a new shaft and the aftermarket bushings with an added o-ring seal plus shim all the side play out of the frame. This way it should be a one shot deal that lasts a long time.
