30 series power steering
sodly
07-05-2006 12:28:20
Can anyone relate what the power steering is like on a 30 series tractor? How does it compare with, say, a 3010? I've always loved how the new generation tractors drove, especially the one-finger steering. Does a 30 series drive the same way? Thanks.
G/MAN
07-06-2006 07:33:47
 Re: 30 series power steering in reply to sodly, 07-05-2006 12:28:20
Depends on the tractor, hydraulic pressure in the steering system, component condition, load on the front axle, etc. There were two different steering systems used on the 30-series tractors. Early ones used the big steering valve similar to the 20-series steering valves, and later tractors went to the hand metering unit and control "brick". That system was then used through the 60 series.
sodly
07-06-2006 07:38:05
 Re: 30 series power steering in reply to G/MAN, 07-06-2006 07:33:47
Which of the two systems would you say is superior? This is a tractor that probably would have minimal front load. Mainly I'm concerned about manueverability and the ability to turn quickly and easily.
msb
07-05-2006 18:35:14
30 series is not the same as a 10 series steering valve.The 20 and the 30 series are alike and take slightly more effort to turn than the 10 series.The later model 30s use a hydrostatic valve that takes even a bit more effort to turn.
Glen in TX
07-05-2006 13:49:38
Like said only if you get a good one. You are going to find many that have a lot of wear in them after that many years and don't steer as well anymore but they can be fixed reasonably and many just need a good flushing, oil change to JD power steering oil, and some adjustments. Others will need more to repair and complete overhaul if worn bad. A I&T shop manual for your model or a JD SM2050 Power Steering service manual will help on repairing one. We irrigated here with ground lay pipe and underground tile pipe with hydrants sticking up out of ground and nothing like coming to the turn row with a hydrant in line and a 730 that suddenly decided not to turn and you almost or do hit a hydrant. Not fun lol. Never had that problem ever with a 10, 20 or 30 series new generation tractor.
Mike M
07-05-2006 13:18:34
If you get a good one they are pretty good and steer easy,but even those at idle when warm fade off. Very hard to beat the steering easy of a 4020 (3010 should be same)unless it is on say a 400 TLB (like a 1020,2020) nothing steers as easy as these !
