Idea on how much the cost is to overhaul 3020 402
J Anton
07-05-2006 12:11:42
I would like to get an idea what the cost is to overhaul engines for JD 3020 & 4020.
No major problems with the engines just some blow by smoke. All of these tractors have +/-5000 hours.
Thanks!
want_4020
07-24-2006 13:08:22
 Re: Idea on how much the cost is to overhaul 3020 in reply to J Anton, 07-05-2006 12:11:42
So you say to do a GOOD overhaul on a 4020 it will cost about $5000.00 ?
G/MAN
07-05-2006 13:33:19
Depends on what you mean by "overhaul". Simply installing new pistons and sleeves using aftermarket parts can be done "cheap", but you'll get what you pay for. If you inspect and recondition every component while you're there - properly rebuilding the cylinder head, doing the water pump, having the injection pump gone through, etc - and use Deere parts, you'll be $5000 in in pretty short order. You'll also need to break the tractors in properly after the overhauls - ideally several hours of varying loads on a dyno. I recent re-overhauled a 3020 that had been overhauled and then piddled around with, causing the cylinders to glaze, low power, oil consumption, etc. He took it to an independent shop to save money, and ended up bringing it here to have it done right.
