Converting from oil bath to paper air filter
Gary from Mules
07-05-2006 10:25:48
I have a 1940 B John Deere and I would like to put a paper air filter element in the original oil bath filter system. Is there any company that makes such a thing or am I off the deep end?
Skyhawk Greg
07-07-2006 08:08:48
 Re: Converting from oil bath to paper air filter in reply to Gary from Muleshoe, 07-05-2006 10:25:48
Gary - I did what you are thinking about on a 1923 Fordson, and am quite pleased with the results. The reason for doing it on the Fordson is that the aircleaners were actually more correctly called air washers, and they used a water bath to clean the air with. The water needed to be drained at the end of each day while the contaminants were still in the solution. By installing a dry filter, the whole water issue was negated. Turns out, there is a stock filter from a Saturn car that fits perfectly within the confines of the Fordson air washer, and it cannot be seen from the outside. As for my Deeres, I don't really see a need to do it. If you wish to pursue this further, I think I can find information on who to contact to have a custom shape K&N filter made - but it will be expensive.
buickanddeere
07-05-2006 18:39:16
A ggod quality paper filter will remove a higher % of the smaller dia particulate matter. The oil bath's main appeal is that it can be serviced cheaply just about anywhere with just a quart of oil and a stick.
Gary from Muleshoe
07-05-2006 16:29:46
Thank you all, from the sounds of things I am just as well off with my oil bath, guess I'll keep and save my money for something else.
F-I-T
07-05-2006 14:19:01
Gary:
Albert at Renaissance Tractor does indeed make a few different conversion kits, but be aware that on some of them, when it comes times to clean or replace the element, you may have to remove the hood and then the aircleaner canister. I know it's that way on a 70D as the element will not drop out and clear the frame rail.
Fran
DSK
07-05-2006 13:05:57
Call Renaissance Tractor at 800-784-0026 or 360-748-0026.
Mike M
07-05-2006 11:53:51
I bet you will find the oil bath filters better and you won't gain anymore HP for pulling with a paper one. If you unhook the air intake at the carb. on a dyno you really don't see a difference.
Drew
07-05-2006 13:38:52
 Re: Converting from oil bath to paper air filter in reply to Mike M, 07-05-2006 11:53:51
On a 60 I saw 3hp on the dyno just taking the cup off the bottom of the oil bath, so there IS horsepower to be had in the aircleaner.
F-I-T
07-05-2006 14:16:47
 Re: Converting from oil bath to paper air filter in reply to Drew, 07-05-2006 13:38:52
Drew:
I have a dyno and after running many trials with regard to air cleaner elements/types, I tend to agree with Mike. Odds are good that if that 60 gained over 7% by removing the oil bath cup that the oil bath mesh was partially clogged, and that's why the gain. Statistically, your sample size was probably a bit too small.
Frank
Drew's old man
07-05-2006 20:07:19
 Re: Converting from oil bath to paper air filter in reply to F-I-T, 07-05-2006 14:16:47
Frank, there's no doubt in my mind that the 60's air cleaner is partially clogged. The next time the hood is off it'll go in the hot tank for a soak unless there is an easier way. I'm open to ideas. Mike
Earl -IL
07-06-2006 06:29:20
 Re: Converting from oil bath to paper air filter in reply to Drew's old man, 07-05-2006 20:07:19
We have found it is best to soak in diesel fuel( several days). Rotate and shake it back & forth you will be amazed how much dirt is trapped. I like to let them air dry. The unstyled tractors I have seen some of the elements rust after washed with water. Earl In Illinois
Mike M
07-06-2006 04:29:44
The older "hot tanks" had chemicals that would eat away the solder that holds those air cleaners together. Just be careful to use something that is compatable. I have done several with a degreaser and a hot high pressure washer and have gotten alot of gunk out of them.
Mike M
07-05-2006 19:57:59
I always get a good laugh at some of the local pullers who bring their tractor by to "check" it. I have done the same ones for a few years running. They worked all winter doing this and that and then we run them and find out they lost power from last time we set them up. Then I go back and readjust the carb. and timing they monkeyed with and it's back up. Dumping out the oil in the cup will gain you the most in the intake system.
