Adjusting working pressure on 3010
randalp
07-05-2006 07:41:22
Hi
Can someone tell me how many .010 shims to add to get a 200 psi rise.
Thanks
Randal
randalp
07-05-2006 19:45:06
 Re: Adjusting working pressure on 3010 in reply to randalp, 07-05-2006 07:41:22
Sorry gents, I mean the impliment working pressure. The standby pressure should be 2250 and the working pressure should be 2000. The external adjustment at the pump is for standby pressure. The working pressure is adjusted by shims. My pressure is down to 1800 psi. I need to add shims, but how many? The shims are .010
Thanks
Randal
RFox
07-05-2006 12:50:55
Are you talking about hydraulic psi? You adjust that by adjusting the stroke control valve on the main hyd pump infront of the radiator.
msb
07-05-2006 07:48:10
What? Where? Injector nozzles? or?
