3010 Top Link adapter
GnRPaint
07-04-2006 10:44:42
All;
Need some help. Recently got a aftermarket top link for my 3010. It didn't have one on it when bought. The problem I am having is that the original link had a u-joint that connected to the bracket which left with the original top link. Is there an adapter that is made than can be used that will fit the bracket and then allow the use of a aftermarket top link?
Thanks ahead of time.
Jason
Rich in ny
07-04-2006 13:16:56
 Re: 3010 Top Link adapter in reply to GnRPaint, 07-04-2006 10:44:42
On my 4020 I just ground a little of the casting away on the bracket to get the clearance. Still plenty of cast iron left for strength.
Glen in TX
07-04-2006 12:31:20
Maybe you got the aftermarket one for Cat.3/2 with bigger ball? Is the hole bigger and needing a bushing for Cat.2 pin? Take it back and get the right one for Cat. 2. You can get the aftermarket ones like the original to replace the AR34208 top link for about $160-195.
Bob
07-04-2006 10:54:50
Why can't you just connect one ball-emd of your aftermarket toplink to the bracket on the tractor?
Or, don't you feel there is enough side-to-side swivel in the aftermarket toplink?
GnRPaint
07-04-2006 11:54:23
 Re: 3010 Top Link adapter in reply to Bob, 07-04-2006 10:54:50
Bob,
The bracket is not deep enough for the ball end of the link to go into. Tried that.
Bob
07-04-2006 12:23:45
 Re: 3010 Top Link adapter in reply to GnRPaint, 07-04-2006 11:54:23
GnR,
I know I've seen the aftermarket units used, but I can't recall just how they did it!
If I get near the places of a neighbor or two that have used the aftermarket units, I'll stop and take a look.
GnRPaint
07-04-2006 18:29:05
 Re: 3010 Top Link adapter in reply to Bob, 07-04-2006 12:23:45
Well, I got it to work, but not until removing alot of the casting. I will see how it holds up, if it doesn't I will just suck up the cost and get one with the universal joint. Thanks for the info guys, appreciate it.
Now if I can just find a new battery!!!!
Jason
Mike M
07-05-2006 13:24:11
 Re: 3010 Top Link adapter in reply to GnRPaint, 07-04-2006 18:29:05
Farm stores like TSC/rural king should have them.
