Hot re-start help, your questions answered
GREEN 51
07-04-2006 08:48:51
Cap is vented on gas tank. Eliminates vapor lock.
Spark plugs in tractor are Autolite 388. If someone has the right plug number, please advise.
I have a 12 volt coil with a balast resistor. After the tractor has run, the coil is warm to the touch, not hot. I checked for spark by the plug at hot re-start, not a real blue flash. Checked compression, 105 and 110, should be OK?
The type of distributor is a Delco Remy, no idea of the model.
What I did find is that if I added gas to the cyclinders, put the plugs back in, the tractor started and ran.
Carburetor has been re-worked by Robert's, could this still be a carburetor problem?
Tractor runs great, high speed, low speed and anywhere in between. Just does not hot start, consistently.
I remain frustrated JD B 51 owner.
Pappy
07-04-2006 15:25:39
 Re: Hot re-start help, your questions answered in reply to GREEN 51, 07-04-2006 08:48:51
If you are using the choke, make sure that the choke plate is actually closing off the air intake. Remove the front pipe from the carburetor and check it out.
To find air leaks around the carburetor or manifold, I use my Propane torch. Turn it on and move it around the logical areas. Just don't light the torch. Place a piece of cardboard behind the fan so it doesn't blow away the propane. Do this outside!!!
B-maniac
07-04-2006 11:03:29
You have proved one thing to yourself already. If you put gas in the cylinders,it will start right up,if I'm hearing you correctly ? That proves it isn't spark or timing or anything else. It proves one of two things is happening.You either aren't getting enough gas when hot,OR you are getting TOO much air when hot.They both will act the same.Sounds like you have checked everything else. Since your little experiment shows that it wants gas to start when hot, what does it do if you choke it? That should also make it draw more gas just like you squirting gas in plug hole,which you said made it start! A warping mounting flange at manifold-to-head or manifold-to-carb or a cracked manifold could cause an air leak. This usually shows up more cold and gets better when hot and expanded BUT that depends on the nature and location or crack or warp. When it is at idle,spray some wd40 around suspected leak areas and tractor should speed up if a leak is found.WD40 has propane in it. What have you got to lose ? You've tried everything else.
Olivergreen
07-04-2006 10:10:36
Try opening petcocks. Seems to help on brothers 48& my 49. It also helps if its floded.
Glen in TX
07-04-2006 10:07:07
Since you have battery dist. instead of mag the 388 plugs should be okay to run. You did say not a real blue spark at plug on restart after hot. Right there I would still suspect the coil but you may also want to try another set of fresh spark plugs or a non resistor type plug like a Autolite 3116 or AC C88L or C88 or Champion D21 or D23. Be aware the longer length D23 may interfere with spark plug shields. Plugs do just go bad and once they are fouled many can't be cleaned to work good again so change them out. Be sure the wires are okay. Metallic cores wires will get more fire to the plug also. Carbon core wires can be used with a battery ignition but will break down also. If swapping plugs, wire, or coil doesn't help look for not enough voltage to coil. Are plugs getting black sooted or clean or wet? May also want to be sure you have on obstucions in air cleaner or intake like mud daubers nests and try resetting carb then.
