4020D oil in fuel?
Fudpucker
07-04-2006 04:13:02
Happy Fourth of July everyone. I've got a little problem (Ihope it's little) that I need some advice on. My 4020D has gotten to where it doesn't want to start in the morning. It will finally fire after about thirty seconds of cranking (or faster with ether). Once it starts it will restart throughout the day fine. It has been running a little rought and I noticed it loosing power when I got into some thick hay while cutting a couple of days ago. I changed the fuel filter and it looked as if there was some oil in the fuel that drained out of the filter. Is that possible? If so how? I cleaned the glass bowel filter on the pump and found it to have a small tear. While getting it back up and running I disconnected the fuel supply to each cylinder one at a time and noticed no change in engine rpm when I disconnected one of the lines. Is that the sign of a bad injector or something else. I am really concerned about the oil in the fuel situation. Any thoughts would be appreciated as always. Thanks in advance.
Fud
Farmersdaughter
07-12-2006 16:57:24
 Allis Chalmers 7000 in reply to Fudpucker, 07-04-2006 04:13:02
Hi, my dad has a Allis Chalmers 7000. He says the fuel injection pump needs to be replaced. Anyone know where we can find this part at a reasonable cost? Thank you for any input.
Fudpucker
07-06-2006 04:00:00
 Re: 4020D oil in fuel? in reply to Fudpucker, 07-04-2006 04:13:02
ET,
You hit the nail of the head. It is the injector pump. It is being rebuilt as we speak. Thanks for all the responses. Have a good day.
Fud
ET
07-05-2006 06:56:16
You are probably going to need your fuel injection pump rebuilt. A check valve may be leaking back so you loose your prime for starting. Is your tractor a early side console with the mini pump on it? I have s noticed this problem several times with that pump. To check for a bad pencil injector, take off the injector fuel return line and fire the engine up. The bad injector will be dumping a large amount of fuel out the back side to return.
johns48b
07-05-2006 04:30:47
did you check your oil? the fuel may be going into the oil pan.
J Schwiebert
07-04-2006 04:47:59
Not all 4020 tractors use the same injection pump or injectors. The cylinder that did not change the output any. Take that injector out and put it in a good cylinder and put the one from the good hole in the one that had no affect. If the "miss so to speak " stays with the cylinder, you have a compression problem, if it moves with the injector get that injector checked before you ruin a cylinder. On the oil in the fuel I am not familiar on how that pump drive is lubricated. However it may be possiable for engine oil to enter the injection pump but it is more common to go the other way.
Fudpucker
07-04-2006 17:00:07
 Re: 4020D oil in fuel? in reply to J Schwiebert, 07-04-2006 04:47:59
J,
I didn't get to check the injector today, but I will tomorrow. I also forgot to mention the tractor has been using a ton of fuel. I cut about 15 acres of hay (average not that thick) with a 9 ft disk mower and it used 3/4 of a tank. don't know if the injector would cause that or not . Thanks again.
Fud
