Alternator on John Deere B
Tim Shanks
07-03-2006 17:25:50
I have a 1941 B and was wondering if it was possible to put an Alternator on it instead of a generator. I"m currently running a 12V battery for starting it with a POSITIVE ground.
Could someone tell me if this is possible, and if so.. How?
Thanks
Tim
Tim Shanks
07-04-2006 21:38:02
 Re: Alternator on John Deere B in reply to Tim Shanks, 07-03-2006 17:25:50
I found this alternator on Napa's website... would this be the GM 10 SI you're talking about?
Link
Hopefully that link works... Otherwise the part number is tem#: RAY2134011 Price: $37.49
Thanks
Tim
John T
07-03-2006 20:26:27
Tim, YES its possible and its easy n fairly cheap if you use a GM 10 SI 3 wire 12 volt alternator versus a One Wire BUTTTTT it also requires changing over to negative Ground which requires you swap the leads on any ammeter and swap the leads on the ignition coil if its a battery powered coil ignition versus a Magneto. Im NOT a big fan of the ugly looking alternators, theyre NOT original buttttt they do provide better charging especially at lower RPM sooooo o if you insist on converting and want to use a GM 10SI 3 wire unit heres how I do it.
WIRING A GM 10SI 3 WIRE ALTERNATOR ON A COIL TYPE GAS ENGINE WITH NEGATIVE GROUND
This is for a GM 10 SI Negative Ground 3 wire 12 volt wire alternator to excite it to make it work like a one wire alternator. FOR NEGATIVE GROUND ONLY
Run a 16 Gauge or so wire from the Ignition switches IGN terminal (what feeds the coil when ON) with a series 10 ohm 5 watt current limiting protection resistor to the lil No. 1 terminal on the Alternators side. (Excitation circuit) NOTE these ratings I use may be bigger than actually required, but the higher rated units have bigger leads easier to wire up. Thennnnn nnn if when you turn the ignition off she still runs from backfeed, add in a series 3 to 5 amp 50 PIV Volt Diode (IT MUST be wired + anode end to switch, - cathode end to alternator). Run a 16 Gauge wire from the Alternators lil side No. 2 terminal jumped up to the big main rear output post. (Sensing circuit) It may be a lil more accurate to sense directly off the batterys + terminal, but this is much easier. Run a 10 Gauge wire from the Alternators big output post up to the Load (NOT to battery) side of ammeter (if it has an ammeter). If theres only a 12 Gauge wire from the ammeters other Supply terminal to the battery or starter etc., I replace it with a 10 gauge.
NOTES: On a diesel where theres no coil and ignition switch I excite the alternator via an oil pressure switch. If the tractor uses an Idiot Light instead of an ammeter, it can be used to serve as the excitation voltage circuit to the alternators lil No. 1 side terminal.
John T Nordhoff in Indiana, retired electrical engineer
Tim Shanks
07-03-2006 21:09:49
 Re: Alternator on John Deere B in reply to John T, 07-03-2006 20:26:27
Let me clearify things a little.
The tractor currently uses a Magneto. So, the only way to turn it off is by shutting off the gas. There is an Ammeter Gauge that is currently not hooked up. There is a ignition key, but, from what I have figured out, the key was used to allow the battery to charge and then not charge. I was thinking of maybe trying to use the key to work the lights... Provided I can get an alternator to work. ALso, where would I come up with a GM alternator? Would this be something that Farm & Fleet would carry?
Thanks
Tim
Hoosier JD
07-04-2006 07:36:04
 Re: Alternator on John Deere B in reply to Tim Shanks, 07-03-2006 21:09:49
Advance Auto Parts (almost any auto parts store), 1979 Camaro (several 60's and 70's GM cars and trucks), $35.00 (or thereabouts), lifetime guarantee. About an hour and I had my 4010 gas switched over and is still going with NO charging problems. Good Luck, Mike.
buickanddeere
07-03-2006 21:34:48
Ignition key and a disconnected ammeter? Sounds like a victom of a tinkerer. Rather than cutting corners and never being happy with it. Purchase a real JD electrical switch. It will ground the magneto and shut off the engine. It will also control the lights bright, dim, rear white and rear red. The existing generator will likely work with a cleaning up and a new voltage regulator to replace the one that doesn't work/miswired/missing. Do you know anybody nearby that does electrical work? It's very difficult to explain something over the internet.
Tim Shanks
07-05-2006 09:53:38
 Re: Alternator on John Deere B in reply to buickanddeere, 07-03-2006 21:34:48
Tinkering??? Yes... But, it was this way when I bought it... Like I said, the ignition/key had cut wires, the ammeter had cut wires, the lights had cut wires and the light switch was frozen.
Also, just to be sure I'm getting the right alternator, I found this one on napa's website last night...
Link
Thanks
Tim
