Serial Number Location on a John Deere 709 Mower
Bill Carlton
07-03-2006 15:49:52
I am trying to get a part for a John Deere 709 Bush Hog Pull Behind Mower and need to find the serial number. The outer part of the pto shaft that goes from the tractor to the gear head is torn up.
The mower is 15 years old; I looked on the mower deck and cannot find the serial number.
The John Deere Dealer tells me they have to know the serial number because there were modifications made to the mower over time.
Can anyone tell me where the serial number may be located?
Thanks
Mike Aylward
07-04-2006 11:14:09
 Re: Serial Number Location on a John Deere 709 Mo in reply to Bill Carlton, 07-03-2006 15:49:52
Bill, the serial number was originally on just a sticker on the right hand side on the reinforcement on the top deck about a foot outside the gearbox. It is quite likely your cutter has lost it"s number. As I remember from my parts manager days, the biggest difference in the cutters is the slip clutch and power shaft, along with the blades having a slightly different mounting bolt. Most cutters out there have the earlier slip clutch (it is the same clutch used from the very first Gyramor days). The very latest cutters have a different slip clutch. If you know which slip clutch you have (there will be pictures at the dealer"s to look at on his parts page) this will give you the major serial number break and will allow you to get pretty close age-wise to what you will need. Hope this helps. Mike
Bill Carlton
07-04-2006 12:49:20
 Re: Serial Number Location on a John Deere 709 Mo in reply to Mike Aylward, 07-04-2006 11:14:09
Mike,
Thanks very much.
Bill Carlton
TimS
07-04-2006 13:38:21
 Re: Serial Number Location on a John Deere 709 Mo in reply to Bill Carlton, 07-04-2006 12:49:20
Go to JDPARTS, put in 709 for the model number and you can review the parts lists and diagrams yourself.
You can mostly likely sort out which part you need that way.
