420 fowling #1 plug with sut.
Tommy R Hogan
07-03-2006 15:19:51
Can anyone explain why this 420 john deere tractor suts the only the #1 plug. you can clean it and it will go back to firing for a short time. Then it will stop firing and the plug will be sutted up again. Any suggestions?
machinery-man
07-03-2006 20:03:17
 Re: 420 fowling #1 plug with sut. in reply to Tommy R Hogan, 07-03-2006 15:19:51
switch to electronic ignition, you"ll up your voltage and clear up the plugs. Consider a kit from Genessee Electronics.
Tommy Hogan
07-04-2006 06:26:20
 Re: 420 fowling #1 plug with sut. in reply to machinery-man, 07-03-2006 20:03:17
Thanks I may try this
Hayfarmer
07-03-2006 18:19:04
I had the same problem on my 430 for a while, was told it was the way the manifold is shaped it tends to pull more fuel up on the #1 side. I rebuilt my carb and that took care of the problem.
Tommy Hogan
07-04-2006 06:24:53
 Re: 420 fowling #1 plug with sut. in reply to Hayfarmer, 07-03-2006 18:19:04
Thanks for the suggestion
Henry M
07-03-2006 18:18:05
Tommy
My experience with the no 1 fouling is that once it fouls, it just won't get back to where it was before, it fouls real quick after the first time. To make it run longer you could drop a new one in or swap it with the back one.
I am gonna stir up a lot of smoke and say that since I put a set of Champs H 12 in mine they have been putting for over a year, only 110 hours though.
I would try just the opposite of making it richer. I crank my main jet down 1/8 of a turn at a time when I have a chance to have it under load. I keep doing this until I am not quite satisfied on how it lugs down and then start back out 1/8 of a turn and stop when she will get down and lug without any hesitation. With mine set like this it will not pull with the choke shoved all the way in until it gets up to operating temperature, but I don't believe in making them grunt unless they are up to running temp anyway.
Another thing to try is to put two gasgets on the front plug.
Tommy Hogan
07-04-2006 06:23:45
 Re: 420 fowling #1 plug with sut. in reply to Henry M, 07-03-2006 18:18:05
Thanks good suggestion
johns48b
07-03-2006 16:03:06
i think john t will come on and give you a good explination. i think your starving the engine for gas. adjust your carb and give it more gas. i think everybody sends people to read jdhpubs.com for good explinations on how carbs work.
Tommy Hogan
07-04-2006 06:22:31
 Re: 420 fowling #1 plug with sut. in reply to johns48b, 07-03-2006 16:03:06
Thanks
