5-2 Powerblock
Larry 2
07-03-2006 12:26:49
I have a 5-2 powerblock without sleeves or pistons. If I am going through the expense of resleeving it, I would like to go larger. How much larger has been done? I have seen others commenting on going larger to 5.5" or 5.75". Has anyone successfully done it? I have a new sets of pistons for an A and 70 that I would like to use if possible.
Larry
Larry 2
07-04-2006 15:48:42
 Re: 5-2 Powerblock in reply to Larry 2, 07-03-2006 12:26:49
Sorry, I misread or misunderstood Drews comments. I was assuming he referred to the crankcase/transmission case on the stroke. I now understand his comments with the additional explanation.
Thanks,
Larry
DSK
07-04-2006 09:56:21
Drew's right on this one, you wil be spending a lot of time with your grinder to make the block fit the tractor. Even the original powerblock sleeves are relieved on the bottom to clear the camshaft gear, so if you plan on going big, you'll be machining that down too. Depending how far you go you will also be losing some of the reinforcement webbing inside the crankcase, thats why some of the big cube 2-cyls. have external reinforcements added, to keep them from splitting in 2 from the cam bearing down.
Drew
07-03-2006 15:42:16
Call Jack @ Jack's Automotive ((402) 654-2217)in Nebraska. He has sleeved several Deere blocks BIG.
Sleeving big is not an option if you dont want to cut the tractor up. Big sleeves require grinding out the front of the crankcase and in some cases narrowing the camshaft gear.
Larry 2
07-03-2006 21:12:50
 Re: 5-2 Powerblock in reply to Drew, 07-03-2006 15:42:16
Sleeving big does not cut out the front of the crank case or camshaft, stroking does. I don"t believe that I will get to the stroke this year. Thanks for the number though!
Drew
07-03-2006 21:16:31
 Re: 5-2 Powerblock in reply to Larry 2, 07-03-2006 21:12:50
I had a big block in an A, and yes, you have to cut the front of the crankcase out to put the block in. The sleeves are enough bigger in diameter that they do not fit into the crankcase without grinding. Then after so big, you have to narrow the camshaft gear because the sleeve is so big and the bore spacing is so wide that the sleeve will hit the camshaft gear. Been there, done that.
