420C Hydraulic Oil in Engine
Larry Hardesty
07-03-2006 12:05:19
I used my 420C to move some dirt yesterday. The hyraulics quite lifting the blade. Looked and the hydraulic oil was low so put some in. Today, the engine oil is way high. How can hydraulic oil get into the engine? How hard is it to fix it. I assume I need to drain oil out of the crawler engine before I try to start it. Just had it overhauled by local John Deere dealer a year ago. Darn!!
Bret4207
07-04-2006 05:02:29
 Re: 420C Hydraulic Oil in Engine in reply to Larry Hardesty, 07-03-2006 12:05:19
There are o rings on the pump shafts that could leak and the hydraulic oil could get into the block. Pull the hyd pump and have them checked. The rings are cheap, the labor is $$$$.
Larry Hardesty
07-04-2006 05:06:43
 Re: 420C Hydraulic Oil in Engine in reply to Bret4207, 07-04-2006 05:02:29
Yes, local John Deere dealer pretty proud of his work$$$$ Not sure he should be since I just had the tractor gone through (including the hydraulic pump) last year (and used crawler only 11 hours) Thanks
Larry
Henry M
07-03-2006 18:23:58
Larry
If you are gonna knock it apart yourself this time, go for the gusto and replace all seals, as I foggily recall there is a one or two large o rings between the pump pieces and check out the bearings, they are very reasonable, but be careful on putting them back to the correct depth as the book specifies.
Make sure your shaft is not cut/worn with a groove where that seal is.
good luck
Larry Hardesty
07-04-2006 03:44:05
 Re: 420C Hydraulic Oil in Engine in reply to Henry M, 07-03-2006 18:23:58
Henry, Thanks for the good advice.
Larry
bill mar
07-03-2006 12:34:41
i think the pump is externally mounted on the front of the engine.will require sheet metal removal and anything else in the way of the pump.if it is the seal leaking the next question you need answered is why did the seal fail.ive changed the pump on john deere model m's before and if i remember right it wasnt too difficult just kinda tight quarters to work in. bill m.
Larry Hardesty
07-03-2006 12:43:22
 Re: 420C Hydraulic Oil in Engine in reply to bill mar, 07-03-2006 12:34:41
Bill, Thanks, Don't know what would cause it to fail. I suppose has to be taken apart and inspected. Just had the entire engine, including hydraulic pump, gone through by local John Deere dealer last year ($$). Larry
bill mar
07-03-2006 13:13:28
 Re: 420C Hydraulic Oil in Engine in reply to Larry Hardesty, 07-03-2006 12:43:22
check with someone in the know, but is it possible for the relief valve built into the control valve to stick or fail allowing the pump to over pressure thus blowing out the seal? i guess once you get the pump off you will see if its a wear issue or what. bill m.
jdemaris
07-03-2006 12:18:24
My memory is a little foggy on the older crawlers, but Deere used main hydraulic pumps and power steering pumps in many crawlers such as the 420 and later 350. If the shaft seal in the pump leaks, the oil goes into the engine crankcase.
Larry Hardesty
07-03-2006 12:41:10
 Re: 420C Hydraulic Oil in Engine in reply to jdemaris, 07-03-2006 12:18:24
Thanks for the information. Just had it all overhauled, including the hydraulic pump, by local dealer about a year ago. Probably not 25 hours on it.
