730D high lift cam
Geoff Mathews
07-03-2006 09:45:40
I plan to rebuild the engine in my diesel 730 this winter. The tractor is still used for field use. More horse power would be useful, does anyone have experience of increasing power for field use by the use of a high lift cam?
Drew
07-03-2006 18:20:58
 Re: 730D high lift cam in reply to Geoff Mathews, 07-03-2006 09:45:40
Like others have said, just adding lift to the camshaft isnt going to help much. Every cylinder head has a point to where adding lift will not flow more air....after this point you could even take the valve out....and its not going to flow any more. The porting and such as discussed before will do as much or more good and it a lot less labor intensive. Make sure the manifold and head ports line up exactly and that the gasket doesnt hang out into the port.
Geoff Mathews
07-04-2006 00:50:03
 Re: 730D high lift cam in reply to Drew, 07-03-2006 18:20:58
I find this concept very useful, ie even if you took the valve out it would not improve air flow - so why bother with increasing height of lift - does anyone have any data or experience to back it up?
buickanddeere
07-04-2006 18:12:55
 Re: 730D high lift cam in reply to Geoff Mathews, 07-04-2006 00:50:03
After a certain amount of lift. The flow may increase as the valve is lifted from 300 to 400 thou. However the flow increase maybe neglegable between 400 & 500 thou lift as the valve is already out of the way.
DSK
07-03-2006 16:28:26
Depending on the present condition of your engine, you may be presently suprised by how much it will wake up just from a complete and proper rebuild. Have the fuel system rebuilt by a reputable provider of this service. Pay particular attention to the governor and its' linkage. Forget the high performance cam, there will be little benefit from it without extensive valve and port work.
Mike M
07-03-2006 16:14:55
If uping the power to hold up to field use was as easy as a bigger cam ,then don't you think JD would of done just that ????? ?? I think they would of as Deere had some real good engineers. Everything is a trade off of long life and drivabilty verses MORE POWER.
buickanddeere
07-03-2006 13:53:23
If the main obstruction to flow is low valve lift then yes a high lift cam with the same duration will increase airflow. You can not make a 730 into a 830 and expect the tractor to be reliable. The classic hot rodding tricks will help. Multiangle valve job, valve bowl blending, port matching, low restriction aircleaner, low restriction exhaust and cam grinding. More efficient cylinder emptying and filling will allow more fuel to be cleanly burned. Temps and component stress will be increased.
Geoff Mathews
07-03-2006 14:30:19
 Re: 730D high lift cam in reply to buickanddeere, 07-03-2006 13:53:23
Is the main restriction to air flow height of valve lift?
JLG
07-03-2006 15:35:50
 Re: 730D high lift cam in reply to Geoff Mathews, 07-03-2006 14:30:19
When I bought a "G" cam few years ago I asked the man I bought it from if he could improve on the cam in my 730 diesel. He basically told me it wouldnt be worth the trouble of getting the cam out for the little improvement I might see. Maybe another cam guy would have a different opinion though.
