730D flywheel woes
mjbrown
07-02-2006 16:41:03
I have a 730D with a taper-lock flywheel that has worked loose. When I drive it back on the crankshaft so that it is close to specs for end play it touches the maincase. Could it be a worn outer thrust washer? Taper-lock collet needs a spacer? Something worse inside the case?
when I put the flywheel on a few years ago I replaced the outer thrust washer and the flywheel was pretty close to the case then.
CarlNY?
Thanks
Carl NY
07-04-2006 09:30:10
 Re: 730D flywheel woes in reply to mjbrown, 07-02-2006 16:41:03
mjb- Do you have a parts catalog for your tractor? If you don't I will make a copy of the parts arrangement and mail it to you. If you have excessive side play you may have chewed up the thrust washer. Call me at 315-946-9041 if you want .
buckeye al
07-03-2006 14:52:46
Been down the same road as Mike M though with a 70D who's seal is a lot different than the 730. A washer worked well.
For other's concerns, mine seems to walk outward presumably because of some taper to the shaft. I've not noted any noise or any additional wear since the JD original with the cracked bolt boss was taken to the scrap yard but have had to "adjust" & re-tighten more than once. Now I watch the crank shaft end play & as it starts to grow, I remove the flywheel, check the thrust washers & adjust accordingly.
One added note..... I find that a wrecking bar positioned hook end on the ground with the prying end set into the ring gear teeth works VERY well as a stop dog to hold the crank still as I wrench the big nut, tap, wrench etc.
Later.
buickanddeere
07-03-2006 08:07:59
I heard Albert talk about a Taper-Loc on a 730 with trashed crank splines. In order to get a decent bite on the remains of the crank. They machined material off the inside of the flywheel to allow the collet to bite in closer to the thrust washer casting cover.
Mike M
07-03-2006 05:52:06
I had the exact same problem on one before. When retightening it up it went back on too far.( The more you tighten the farther back they move. ) I guess due to more wear and seating in ? I ended up getting a machinery washer and putting on the crank to space the collet out farther and it worked fine.
mjbrown
07-03-2006 06:06:19
 Re: 730D flywheel woes in reply to Mike M, 07-03-2006 05:52:06
It's good to know it's not just mine! I was thinking of the same solution. The collet has a tooth to engages the slinger. Is it long enough to still work with a spacer? I assume you have to make a cut out in the washer for the tooth.
Do you still use a stake nut on the crank end? I can't seem to make the flywheel stay on in spec without one.
Mike M
07-03-2006 16:09:59
 Re: 730D flywheel woes in reply to mjbrown, 07-03-2006 06:06:19
Any of the taper locks I've used I think the center collet part entirely covered up the crank end. Also the tractor I put the spacer in I'm thinking was a late 720 D do those use that driver pin ? I don't remember having to notch the washer ,but if it used a pin I'm sure I had to notch it out somehow so the pin would engage the spacer.
Those taper locks use a threaded in set screw for the pin so you could drill a hole in the washer and put it under the set screw drawing it tight to the flywheel.
DSK
07-02-2006 18:00:19
You say the flywheel came loose. Did it damage either taper on the sleeve or in the flywheel itself? I would think that more than likely that's what happened. If you didn't lose too much material, I would try replacing the thrust washers first. The people to ask about this would be The Allen Machine Works Co. 423-753-5738, they have alot of these flywheels out and should be able to help you. If your taperlock is made from an original JD flywheel, you could tighten the two clamping bolts a little to make the center hole a little smaller, ask them about this first as these bolts are sometimes pre-torqued and welded before the taper is machined into the flywheel. Alot of people don't know it, but there is a tightening procedure that needs to be followed when installing a taper-lock. When you have the nut drawn up as tight as possible, you need to seat the taper by bumping the flywheel hub while tightening the nut some more. Repeat the bumping and tightening procedure until you can't tightenen the nut any more. You really can't make them too tight. The best way to hold the crank is to remove the crankcase cover or starting engine and block the left throw with a piece of hardwood...a lot of work but the right way to do it. The flywheel should be re-tightened occasionally, maybe once a year.
mjbrown
07-03-2006 05:29:03
 Re: 730D flywheel woes in reply to DSK, 07-02-2006 18:00:19
Thanks for the info. Count me as one of those people who didn't know the bump and tighten procedure also I should have retightened anually as I now know.
I got the flywheel used though it looked and I think is fine. It has the letters AMW on it so I think you have given me the number of the manufacturer and I'll give them a call after the holiday.
