JD 4010 Fuel Gauge troubleshooting?
TimS
07-02-2006 09:03:22
The fuel gauge on my 4010 seems to not be working properly, any hints on troubleshooting it?
From looking at the wiring diagram the gauge gets its ground signal from the fuel sender and that moves the needle on the gauge?
Leland
07-02-2006 21:50:56
 Re: JD 4010 Fuel Gauge troubleshooting? in reply to TimS, 07-02-2006 09:03:22
We gave up on ours and now carry a broken off broom handle does a good job of measuring how much fuel is in tank .
Glen in TX
07-02-2006 09:46:45
If you have another old fuel guage sender laying around or a potientiometer type switch (variable rotary resistor type, heater switch) around hook it to the wire from guage at sender and other side to ground and move it back and forth seeing if guage works right? That way you won't have to drain fuel or remove anything yet. If nothing happens on guage the wiring or guage is bad or no current to the guage. If it works suspect the sender or sender ground or bad float. The sender is like a potentiometer and a resistor type switch. JD service manual should give you resistance values of receiver and sender?
Fuel Guage shows empty:
*Bad ground at sender
*No current to receiver(guage)
*High resistance or open circuit in wire between receiver and sender
*Hole in sender float
*Bad receiver or sender
Fuel guage shows full:
*Grounded wire between receiver & sender
*Bad receiver or sender (usually the sender)
TimS
07-02-2006 11:38:17
 Re: JD 4010 Fuel Gauge troubleshooting? in reply to Glen in TX, 07-02-2006 09:46:45
It turned out to be the sender had fallen apart and the float had a hole in it as well.
I fished out the float and its wire that its on, there was also a little metal fitting and a second piece of wire. I am half afraid that a piece that goes between the sender and the metal piece the wires hook to might be in the bottom of the tank yet.
Glen in TX
07-02-2006 12:41:15
 Re: JD 4010 Fuel Gauge troubleshooting? in reply to TimS, 07-02-2006 11:38:17
If you can't fish the other piece out with a magnet or fish tool it might not hurt anything. Think most of the shut off valves in bottom of tank had a slotted tube or screen that stuck up some inside the tank anyway. Slim chance it could block it or might not bother anything to leave it in there.
TimS
07-02-2006 16:55:22
 Re: JD 4010 Fuel Gauge troubleshooting? in reply to Glen in TX, 07-02-2006 12:41:15
I might run a magnet down around in there and see if I get anything out, there is fuel in the tank till just below the sender hole so it's hard to see anything.
