JD-H BASE GASKET
BLB
12-03-1999 15:55:01
WHEN ASSEMBLING THE ENGINE IT SAYS IN MY (IT) SERVICE MANUAL TO SOAK THE HEAD GASKET IN OIL BUT IT SAYS NOTHING ABOUT THE BLOCK BASE GASKET!! SHOULD I SOAK THAT ALSO? USE GASKET SEALER ? ASSEMBLE DRY? ANY OPINIONS....THANKS
STMTS
12-03-1999 17:28:30
 Re: JD-H BASE GASKET in reply to BLB, 12-03-1999 15:55:01
Have you already soaked the head gasket? I don't do that I use spray copper coat,applied to the block and head surface only .Don't spray on the gasket!And on the block gasket go get some # 515 locite gasket stuff and apply to both sides ,those pesky blocks are oozers.The 515 is good on most gaskets its really gasket elimator but it really works good with a gasket.
