70d pony
stu in njo
07-01-2006 20:02:38
I have a oil leak above #4 cylinder.I don't think its the valve cover but can't see were it is. Has anyone had this and is there a quik fix.Thanks Stu
F-I-T
07-02-2006 07:27:11
 Re: 70d pony in reply to stu in njo, 07-01-2006 20:02:38
Stu:
What are you calling #4? It could be a leaking oil gauge line, or a worn diesel engine creating excessive blow by with no where for it to go except out the pony breather.
Valve cover is about the only pony item with oil behind it. Could you have a clogged oil drain back hole, and it is collecting oil that the valve cover gasket cannot hold back?
Frank
stu in njo
07-03-2006 06:29:58
 Re: 70d pony THANKS in reply to F-I-T, 07-02-2006 07:27:11
I'll try that screw and let you know. THANKS Stu
Dan in Ohio
07-02-2006 10:54:37
 Re: 70d pony in reply to F-I-T, 07-02-2006 07:27:11
Stu, I have seen the rear rocker arm screw loosen up and leak oil in that area on my 70 D. If it has comme clear out it will definitely leak some oil, hopefully it is just loose. You can see a good picture of it in the service manual(same type of screw is visible from the door side) but the one you describe is on the back and that is the one I had leak. I used a short srew driver with a one inch right angle bend in the end(no handle) and a lot of patience. You can fix it too.
I'll second that
07-02-2006 11:35:10
 Re: 70d pony in reply to Dan in Ohio, 07-02-2006 10:54:37
I have seen that same thing happen several times. You may be able to tighten the screws, but they also have a little o-ring type seal in there as well. It may need replaced.
