830 clutch problems-HELP
Van
10-28-2003 08:19:58
I recently bought an 830 electric start. It runs good, but the clutch won't "POP". I have checked the discs and they are good. You have to hold the lever where you want it to do. You have to hold the lever forward to keep it engaged. Could it be bent clutch forks? Or is it the dog on the operating sleeve bad? Anyone have any ideas or help? Thanks in advance!
Clooney
10-28-2003 09:22:53
 Re: 830 clutch problems-HELP in reply to Van, 10-28-2003 08:19:58
Van, it could be as simple as a clutch adjustment.
~You should start with a clutch adjustment. If it still won't lock in with a snap it could be [probably is] worn parts. A worn sleeve, worn sleeve drive pin, worn pivots, worn fork, or any multitude of other worn parts could be to blame.
~About your only option is to dis-assemble the clutch & see if you can identify any excessively worn parts..
[email protected]
