JD 345 Voltage Regulator
Tamony
06-30-2006 16:54:11
Have been told JD 345 needs VR replaced. Wondering if it's something I can do at home. Any special tools required? How difficult for a rookie? Thanks!
Tony
Henry M
07-01-2006 13:19:51
 Re: JD 345 Voltage Regulator in reply to Tamony, 06-30-2006 16:54:11
Tamony I apologize, I mix numbers ua a lot and you 345 came out as a 435 when my wires got crossed.
Bob
07-01-2006 08:40:27
345 lawn tractor?
If so, there is a connector in the wiring harness that commonly fails (overheats and melts).
Check that first.
And, it's an alternator, so DON'T polarize it!
Henry M
06-30-2006 17:57:50
Tamony
Probably just need a screwdriver depending on that type of heads the mounting bolts have.
As i recall things need to be repolarized and the last one I did had the instructions with the new vr.
