Changing JD BR from 6 volt to 12 volt starting
David in Englan
06-30-2006 15:30:42
third party image
Hi;
I have a late 44 BR electric start with 6 volt electrics. The tractor was "restored" 10 years ago and has a new battery. When Ive finished playing, I disconect the battery terminals.
BUT after a week or so its hard to start, turns over very slowly, often too slow to start.
How difficult is it to convert to 12volt, which would turn the engine over faster.
Any suggestions on which parts need changing. I believe the 6volt wiring will take 12 volts without any problem.
All replies gratefully received.
Thanks David
Pete76NY
06-30-2006 22:15:02
 Re: Changing JD BR from 6 volt to 12 volt starting in reply to David in England, 06-30-2006 15:30:42
Dave, In my opinion that tractor is WAY TOO nice to have an alternator sticking out the side...clean the terminals, load check your battery, check to make sure it's charging properly, and see if you have a short somewhere, 10 years can eat up some wiring too, so check that thoroughly, make sure your cable is heavy enough, and there really is no reason it shouldn't be fine with a 6v system. The only 6v tractor I have ever had the need to tweak at all is freshly rebuilt Super M Farmalls, and an 8v battery and a small voltage reg. adjustment cures that! Nice tractor! Send it over here to NY if ya get fed up with it! Pete
DCM
06-30-2006 21:18:40
Nice tractor Dave, I had my starter reworked,actually the flat head screw that goes into the casing was too long and was grounding out the field, my 6 volt battery cranks those 2 pistons as if it were 12 volt,my opinion is that it is too valuable a tractor to not keep stock but that"s just me,good luck,Dan in Alberta
John T
06-30-2006 16:56:59
Nice lookin tractor, usually a B if in any kind of shape at all and IFFFFF F you use the biggest heaviest rated highest CCA and Amp/Hr battery that will physically fit in the compartment PLUS 00 Gauge Battery n Ground Cables and assuming the starter is good???? OUGHT TO START FINE ON 6 VOLTS. Maybe all you need is big 00 Cables with a good solid main frame bolt ground and a big super heavy duty battery????? ????? ? Or else maybe the starter motor needs attention or maybe you need a new battery????? It shouldnt run down when sitting if its a good battery and theres no wiring shorts draining it or other VR problems HAVE A SHOP TEST N LOAD TEST THE BATTERY !!!!!
HOWEVER if you wanna swap to 12 volts you need:
12 volt battery,,,,, ,It looks like a Mag???? so if it is no ignition change is required,,,,,you can get the genny rebuilt as a 12 volt and you need a new 12 volt Voltage Regulator ORRRRR RRR get another 12 volt genny ORRRRR RR just change to a 12 volt VR with the existing genny (NOT engineering correct but it does work),,,,, ,,,,change any lights to 12 volt.
If its a battery powered coil ignition post back for more directions cuz all you would need is a series external voltage dropping (12 to 6) Ballast Resistor after the switch n before the coil or else buy a true full 12 volt rated internally ballasted coil.
John T
F-I-T
06-30-2006 16:44:02
third party image
David:
Are the Optima brand gel cell batteries available in the UK? I use them on all of my 6 volt systems, and while looking a bit unconventional, they can be mounted in any position (even upside down), and at an available cranking amperage output of 1000, it should spin a BR with no problems. Also, they hold a charge for weeks on end for me, so they function well in the seldom used, but when used, heavily category.
Frank
