CARB PROBLEM
DGK
06-30-2006 15:23:34
Hi Have B John Deere runs good idling with the idle needle 4 turns out. Load needle turned all the way in but won't pull any kind of load. If you back the load needle out it smokes black smoke but still won't pull any load. Thanks for the help DOUG
Skyhaw Greg
07-01-2006 19:10:39
 Re: CARB PROBLEM in reply to DGK, 06-30-2006 15:23:34
DGK - Several things could cause this. Here is an unlikely, yet possible cause. Something that happened to me not too long ago was that the load needle seat within the carb had eroded over time to where there was a crater instead of a nice round hole. This made the taper of the needle rather useless, and the mixture went from too rich to too lean with the slightest amount of adjustment. Hopefully this isn't your problem, but still worth investigating.
Duane Larson
06-30-2006 19:39:04
DGK,
If I read correctly you have a DLTX71 carb? If so, that is sized for a late styled A with a gasoline burning engine and would be too big for a B. What is the year or better the serial number of the B? If it is later than 201000 it should have a DLTX67 for the gas engine. If the 71 is the carb you have to work with, the fuel level setting is important and can be checked by using a 1/8" NPT hose barb in place of the bowl drain, and a piece of clear plastic pushed over the barb and held up alongside the carb bowl. The fuel level should be 3/4" below the top of the bowl. Initial settings should be less than 1 1/2 turns for both idle and load needles.
DGK
06-30-2006 19:03:11
P Browning Thanks jsn an P Browning for replying. The B is a good freinds, and he thinks I can fix anything! He has had the carb # 71 apart many times so have I, the mag has been rebuild, valves set at 20 th.hot sprayed either arround manifold. New plug wires with wire core,2 sets of champion d21 plugs, guess I am wondering about float level. It seems to Idle nice and even wide open until you put a load on then it will drop flywheel side plug. Air cleaner pipe unhooked. I tryed H carb section but all I got was ;kjhdsafkglisd looks like you have to buy cd. Thanks FOR THE HELP DOUG
P Browning
07-01-2006 05:21:39
 Re: CARB PROBLEM in reply to DGK, 06-30-2006 19:03:11
DGK -- I so much appreciate hearing back from a fellow on problems like these. Judging from your come-back, you found some fault when you run the IDLE & LOAD tests you found on my site, and from both yours & Duane's remarks that using the DLTX-71 carb on the B demands very close settings -- it is a bit over-sized for the tractor.
Yes, if the IDLE pathway is blocked, it needs to be cleared! And as for the LOAD, the acceleration cavity which contains the fuel nozzle needs to be cleaned out too. And yes -- one of Robert's Carb CD's (actually a DVD) or a tape will be helpful. Get the Carb-2 one. Enjoy! (PatB)
jsn in pa
06-30-2006 18:10:50
just finished restoring a B had some what the same problem found out i needed to start with timing make shure it is set right after i knew that was ok then run engine till it is at operating temp. set high speed first then bring to idle and adjust that and probably idle speed will need to be reset too keep in mind that there is a fine line of being to rich or to lean these old tractors will throw some black smoke on excceleration and under hard load if its to lean you will over time burn a hole in the pistons and also i have had overheating problems that where caused only by being to lean in a john deere 2 cyl tractor ,hope i was of some help
P Browning
06-30-2006 16:10:58
DOUG -- Far too much data not given! Does the tractor have a good running & pulling record up until recently? Has the carburetor been worked on in recent times? Are you certain your fuel is clean? Are you sure the engine air-in path is clear? Is the gasoline in the fuel tank old? Has it been sitting in the tank for several months? Really old gasoline can present some challenging grief!
On the carb -- There are two fuel systems, or two paths for fuel in your carburetor, one for IDLE and one for LOAD. Go to the JD-H Restoration Site listed below, click on Carburetors, and you will find much easy-to-understand data on John Deere single barrel, natural-draft carbs.
Carburetor settings -- With the LOAD needle all the way in, you have closed the LOAD fuel path and most surely can not expect the tractor to even accelerate much less pull anything! As far as it idle-running fine with the IDLE needle 4 turns out, this is not right. But in itself tells nothing much. The initial settings of those needles are not at all critical to starting the engine. And so I would return to a basic setup of (say) 1-3/4 turns out for IDLE and 1-turn out for LOAD; and experiement from there. SPECIAL TEST -- While at the JD-H Restoration Site & in the Carburetors section, go to page 7 and you will find a no-wrench test to determine if there is any blockage in either of the two paths in the carb.
Black Smoke -- This is indicative of a air-fuel mix that is too rich. This can come from too much fuel or air starvation. (1) Too much fuel can arise from a malfunctioning float needle valve, or some debris which isn't allowing the float needle valve to close. Place a catch basin under the carburetor drain cock, open the cock and allow free flow of fuel for about a minute -- to hopefully flush any loose debris through and out of the carb. Examine the fuel in the catch basin for any sign of trash in the fuel channel. (2) Air starvation can arise from a clogged up air intake stack. Unbolt the air inlet elbow from the air-in end of the carburetor enough to allow a separation of the two by at least 1/8-inch. Then operate the engine and see if it appears normal. Then, while it is running, tighten the bolts back -- shutting off this alternate path for input air. Reappearance of the black smoke will tell you that the engine air-in path is blocked. Think Dirt Daubers!
Please write back to let us know what you find. (PatB)
