3020 identification
W5GA
06-30-2006 10:04:40
I'm buying what I think is a first year of production 3020 (gas). The serial is SNT711R001630R. Can someone peg the year and whether or not my I.D. of the tractor is correct? I based the I.D. on tire size (15.5 x38) and location of some of the components. The pto lever is to the right of the cowling. And it looks like some of the pix I've seen on other sites.
Thanks!!
Glen in TX
06-30-2006 21:13:44
 Re: 3020 identification in reply to W5GA, 06-30-2006 10:04:40
third party image
Forgot I had put this one of 2510 on vintage photos here and also some more of 2510 versions and 3010.
j cook (iowa)
06-30-2006 19:35:49
 Re: 2510 gas identification in reply to W5GA, 06-30-2006 10:04:40
Glen in TX is absolutely right about the breakdown of that particular serial number code, and be glad! A 2510 is a very desireable tractor, even if it is gas. Another thing to look for on your tractor, is the shape of the side covers. The ones on the 3010/3020 are flat, but those on the 2510 and 2520 are curved. The Muffler is slimmer also.
msb
06-30-2006 18:51:22
3010 PTO lever is on the left side of the dash panel.2510 & 3020 on the right side.
95EB
06-30-2006 11:41:12
A tractor with that serial number is a 2510 gas row-crop, a 1966 model.
Glen in TX
06-30-2006 10:32:28
Is that the engine tag number or one off the tag on back of trans by PTO ? You go by the one off back of trans. JD book and blue book both show 1964 first year 3020 numbers started at 50000.
W5GA
06-30-2006 11:08:28
 Re: 3020 identification in reply to Glen in TX, 06-30-2006 10:32:28
It"s off a tag on the back of the pto housing that"s riveted on. The tag is to the right of the pto shaft.
W5GA
06-30-2006 11:10:10
 Re: 3020 identification in reply to W5GA, 06-30-2006 11:08:28
I've seen the 50,000 number on a few sites. I was wondering if that's where the serial #'s started, or where they ended?
Glen in TX
06-30-2006 11:37:10
 Re: 3020 identification in reply to W5GA, 06-30-2006 11:10:10
Did you mean a 3010 ? 1961 3010 began at 1000, 1962 at 10801 and 1963 at 32400. The John Deere Tractors 1918-1994 shows serial numbers in back with 3020 being 1964-72. Shows 1964 starting number was 50000. 1965 starting at 68000 and so on till 72. The apparently continued the numbers from 3010 on into 3020 series.
W5GA
06-30-2006 11:41:10
 Re: 3020 identification in reply to Glen in TX, 06-30-2006 11:37:10
It could well be a 3010. There are no other identifying marks on it. No decals or anything. Is there anything else I might look for to cement the I.D.?
W5GA
06-30-2006 11:55:43
 Re: 3020 identification in reply to W5GA, 06-30-2006 11:41:10
95EB, many thanks!! That's what I was looking for. What did you use to decode the S/N?
Glen in TX
06-30-2006 13:08:34
 Re: 3020 identification in reply to W5GA, 06-30-2006 11:55:43
Easy once you look in 2510 parts book lol.
SNT = Tractor
7 = 2510
1 = Row Crop
1= Gasoline
R = Syncro-Range trans
001630 = serial number
R= John Deere Tractor Works
If you are interested in some almost like new 2510 manuals contact me. :)
95EB
06-30-2006 12:17:26
Let's put it this way, it's my business to know about such things.
