More 4010 Hydraulics
KWGray
06-30-2006 09:03:42
I have a "61 4010 with 2 remotes. The right side outlet (looking at the back of the tractor) lets the cylinder will slowly retract or extend (depending on how the hoses are connected) until they maximum extension or retraction. Is this a adustment problem or does the top selective control valve need service?? Thanks!
msb
06-30-2006 18:58:49
 Re: More 4010 Hydraulics in reply to KWGray, 06-30-2006 09:03:42
One the front of the box there are two adjustments.The small one with an allen head screw sets the spring tension on the detent.The large one has a screwdriver slot in it.Loosen the jamb nut and turn the screw counterclockwise to increase the rate of extension and retraction of the cylinders.The proper adjustment allows for the cylinder to fully extend or retract in 2 seconds at wide open throttle.
ET
06-30-2006 09:17:22
The valve needs to be serviced by your dealer. It takes some special tools to grind the seats and reset the pressure and return valves.
