4240 PTO slow to disengage
MDM
06-29-2006 22:30:14
My 4240 PTO is slow to disengage, when using it on feed wagon with little resistance, it may take up to 1 min before it stops. On the baler it shuts off better but still turns after lever is pulled for a bit. I have tried to adjust the cable but with no improvement, any ideas?????
Mathias NY
06-30-2006 08:48:43
 Re: 4240 PTO slow to disengage in reply to MDM, 06-29-2006 22:30:14
If the tractor is running and the PTO clutch is disengaged and not rotating, you should not be able to turn the PTO by hand. If you can, the PTO brake is not functioning properly.
Tx Jim
06-30-2006 03:26:43
I think that your pto brake is worn also you may have some warped clutch plates. Have you checked your pto clutch and brake pressures? Tx Jim
