530 automatic fuel shut-off
ol' guy
06-29-2006 17:11:51
earlier i posted a message regarding the neoprene gasket hanging up when the valve is open resulting in inadequate fuel flow. i received some good suggestions to help the problem, but today at a jd gathering one mechanic told me that the neoprene part i.d. has been changed so that it fits "better" but he suggests that it should be "glued" to the bottom of the valve when a new neoprene part is installed. Has anyone tried this, and does anyone have a suggestion for a sealant/glue that will tolerate the gasoline environment. Thanks for the help.
Mike M
06-30-2006 05:06:11
 Re: 530 automatic fuel shut-off in reply to ol' guy, 06-29-2006 17:11:51
Maybe a product like seal-all .I think it can be used to patch gas tanks.
I had on stick on my uncles 630 it was driving him nuts. I was luck to find out what the problem was quickly. I just happened to notice that the washer was stuck up while it was running. Took off fuel bowl pulled it down and maybe even turned it some and I don't think it stuck anymore. This was after a recent rebuild of that unit too.
FredWi
06-30-2006 05:04:32
I just changed mind on my 730 and have
no problems with it. I would think the glue or
whatever would just make it harder to replace
down the line.
Mr Mark
06-29-2006 18:44:44
I have had the same thing happen to me. No, I do not know if it could be glued. At least you know it can happen and it's easy to check.
machinery-man
06-30-2006 04:11:36
 Re: 530 automatic fuel shut-off in reply to Mr Mark, 06-29-2006 18:44:44
Ole guy, I"ve rebuilt several of these and have never see this issue before. The spacer has always fit tight. The only issue I"ve ran into is the base has to be smooth where the gasket meets and I"ve always used a file and smoothed it off. The spring pulls the valve closed. I wouldn"t think any kind of glue would work.
