4010 Hydralics, constant flow?
MN Bob
06-29-2006 13:33:17
I have an accumulator for small bales, (8). I cannot mount the pump I got with it to the baler as it was before, (different model). Best thing for me would be to run it off the tractor. The sensors tell the accumulator when to work a push bar and when to run the chain for off-loading bales. Do I need to do anything to the hydralics on the tractor? Would I just push the lever to raise and it would do it? Last ?, What is the difference in Hyd. on the left as opposed to the right side of tractor. Manual stipulates using loft for some things and right for others. Thanks for your help: Bob
msb
06-29-2006 21:15:32
 Re: 4010 Hydralics, constant flow? in reply to MN Bob, 06-29-2006 13:33:17
The left valve has a valve so a single acting cylinder on a wagon hoist( for instance) will come down without taking two days for the return oil to get back out of the hoist. Why not use the front PTO to run an auxilary pump.
KIP in MX
06-29-2006 14:06:51
I�ve never seen a Farmhand bale accumulator use tractor hyd. system, only a PTO or baler mounted pump. There must be a reason for not using the tractor�s system.
G/MAN
06-30-2006 07:29:43
 Re: 4010 Hydralics, constant flow? in reply to KIP in MX, 06-29-2006 14:06:51
Probably so no modifications are needed to the accumulator hydraulic system relative to what sort of hydraulics the tractor has - open-center, closed-center, etc.
G/MAN
06-29-2006 13:46:03
The 4010 uses a closed-center/constant-pressure system, meaning that their is "no" flow in the system when a function is being used, at least not beyond what is required to make up for leakage at various components and keep the pump out of stroke. When a function is used, the pump goes "into stroke" to supply the needed oil. The pump maintains a constant pressure in the system around 2300 psi. Not sure on what the differences are in the system as far as right vs. left, as a lot of 4010s only have one remote anyway. I'd have to look in a manual for sure. But it sounds like you're going to need two separe functions - a constant supply of oil to an accumulator to keep it charged, and the other circuit to run an orbit motor and drive the chain. Correct? Or are both systems running off a common supply? Either way, you'll likely just need to put the lever in detent, either forward or back depending on which way your hoses are connected as one coupler is "retract" and one is "extend".
