420 U howl noise
Tom in Central
06-29-2006 04:27:07
When the tractor is running, it sounds good, at any speed. Moving or parked. At random times it will begin to howl, it sounds like a dry, worn-out ball bearing. When I push the clutch pedal, it quits making noise.
I re-bearing-ed the whole transmission and pto.
Throw-out bearing is greased, and has correct free-play.
To my amazement, it still does the same noise.
any ideas?
Henry M
06-29-2006 09:19:15
 Re: 420 U howl noise in reply to Tom in Central Pa., 06-29-2006 04:27:07
Tom
My 420 W makes an intermittent howling noise, I always have attributed that one to hydraulics, but have never tried jumping on the clutch. It winds up and when it sounds like she is gonna blow the noise suddenly disappears.
I donno - but have had the tranny down to the bare case twice - never again unless she blows.
Wayne in Tn.
06-29-2006 08:23:32
Tom, pushing in the clutch stops the main shaft in the trans from turning.
I have been chasing those howls in the Dubuques for many years, and finally gave up. Its those straight-cut gears in the trans.
Replacement with used gears is usually no different, and no way you could buy all new gears. I have learned to just live with it.
If you ever run across a Dubuque that does not howl, better keep it.....
