620 clutch fork timing
jdjack
06-28-2006 16:56:44
I have a 620 that has some problems with the clutch. I beleive that somebody has removed the clutch fork shaft from fork. Is there a timing mark on them?
2cylinderlp
06-28-2006 17:42:36
 Re: 620 clutch fork timing in reply to jdjack, 06-28-2006 16:56:44
I don't recall seeing any timing or registration marks. I've had a number of them apart and they always seemed go back together and work fine with the fork set right at about 90 degrees to the lever end on that splined shaft. What kind of trouble is your clutch having?
jdjack
06-28-2006 19:29:42
 Re: 620 clutch fork timing in reply to 2cylinderlp, 06-28-2006 17:42:36
Clutch is very hard to engage, but is easy to disengage. The 3 adjusting nuts are backed off even with end of studs. Had clutch apart and had to press gear back on because started to slide off ( clutch would not disengage).
2cylinderlp
06-28-2006 21:35:38
 Re: 620 clutch fork timing in reply to jdjack, 06-28-2006 19:29:42
I apologize for having more questions than answers concerning your clutch problem. But I can't figure it out without a better picture of what is going on there. I think that normally that gear is fairly hard to get off. I have never tried to take one off. But it concerns me that you say it started to slide off. Is that what actually happened? I haven't heard of that before.
I'm assuming though you have the gear pressed on securely now. Does the operating sleeve move freely back and forth? Is the pin that keeps the operating sleeve lined up in place? Is the hole that the pin goes through excessively worn? Is the brass collar worn excessively or cracked? Is the collar properly engaging the operating sleeve? Are the dogs and toggles in good shape and were all those parts cleaned and lubed? If everything is put together in the right sequence you should be able to turn the pulley by hand with the clutch disengaged(as long as the pulley brake pad isn't too tight). You can do that can't you? I'm sure you know that until you get the three nuts tightened up you won't feel much of anything in the clutch linkage. Sorry to sound so simplistic but we always have a tendency to think complicated and tend to miss the simple things that are usually the source of trouble.
jdjack
06-29-2006 04:34:01
 Re: 620 clutch fork timing in reply to 2cylinderlp, 06-28-2006 21:35:38
Yes gear is pressed back on and pulley does turn by hand.
Going to take apart again and check everything over. will let you know later.
2cylinderlp
06-29-2006 10:54:05
 Re: 620 clutch fork timing in reply to jdjack, 06-29-2006 04:34:01
I'm guessing worn internal mechanisms prevent it from getting a good over center snap, and therefore it can also easily disengage. So you really have to push it to get it to seem to snap in at all. Is that how it is? I had one like that recently and it turned out to be cracks in the brass collar, allowing the collar to flex when it should be pushing the operating sleeve. But wear in other parts, such as the dogs/toggles could do that too. Also that alignment pin and wear in the hole that it goes through on the sleeve can be the issue. So just to clarify, when you say the clutch is hard to engage, do you mean that it just doesn't want to snap in? Or is it that it slips and doesn't want to move the tractor?
RLA
06-29-2006 09:24:19
I too have a 620 with a touchy clutch, 6221964 & I"ve replaced everything with the exception of the pulley. The end result is the same, hard to engage & at wide open occationally disengauge. What I have found is the pulley itself is cut too deep at the 1st clutch lining. What I did to help me correct it was install to worn clutch disc back to back next to the pulley. I am the second owner of this low hour"d 620 & the orginal own said it was always hard to engauge but after years it started to disengauge by itself. I have a 630 & the clutch works great, so I switch pulley"s & it worked great just like the 630. So my Plan is to someday install another pulley that isn"t cut so deep. I also know of other 620"s with the same problem . What is happening the clutch driving on the outside disc & not the inside ones. I mean I replaced everything excluding the pulley & operating sleeve, which I have never seen on come apart. Crank end play is correct & the drive isn"t worn..
That is my 2 cents on 620 Clutchs, alot of money without any results, but I love this tractor.
RLA
