Beware of Mis-Identied Service Manuals
P Browning
06-28-2006 16:48:43
Procuring the basic three manuals (1) Operator's Manual, (2) Parts Catalog and (3) Service Manual is the most successful place to begin a tractor experience with your new tractor.
CAUTION: At least one web-seller is claiming the SM2000 to be THE service manual for the model "H" John Deere, and also for the Model "A". As many know, this is a very general manual whose greatest claim of any value is in the subject areas of electrical systems and carburetors -- little else really.
Be advised that so far as I can determine, Deere produced a service manual for the Model B John Deere only. And so today's most economical service guide for the JD-H is JD-4 (I&T) Shop Service Manual. While not the greatest, when used in conjunction with the Parts Catalog and Operator's Manual, it generally gets the job done! Having the JD-H Restoration Guide, 2nd Edition makes your data package complete!
I believe JD-4 is equally okay for the styled Models of A, B, G and for D-143800 & up. There is also a section for Models M & MT but I have no first hand knowledge of how well these models are developed.
The gist of this post -- do not be fooled into thinking that SM2000 is a service manual for your JD-H tractor! (PatB)
Glen in TX
06-28-2006 22:27:56
 Re: Beware of Mis-Identied Service Manuals in reply to P Browning, 06-28-2006 16:48:43
What is in the SM2000 ?? I have the SM2000 and it is titled "Tractors & Engines (General)". In other words it is suppose to be a general catch all service manual but really isn't that. Maybe the original copy was? Got my copy in late 80s from JD and it has a chapter on shop tools, tool and shop safety, welding equipment, how to fill tires with calcium choride in short. A good chapter in it is valve reconditioning chapter if you had your own valve grinder and seat cutters but how many of us have that?? The valve and guide spec. wear chart is good and covers most all the letter series gas and all fuel 2 cylinders including the M & L but does not cover any of the early diesels. The seat cutter chart is for use with Black & Decker tools. The carburetor chapter is a short condensed version of the SM2024 Carburetors and service only with no application charts or the like. Has a spark plug chart but only gives the old numbers of plugs you can't get now so kind of useless. The best chapter in SM2000 is the electrical one that covers service, testing, repair & overhaul and specs. for starters, generators, relays, regulators, distributors & magnetos. Most of the testing it shows is done with the old Allen test equipment JD dealers had then. Also shows you how to use a armature growler and polarize. Too bad they just couldn't put that chapter in the SM2029 Electrical that has wiring diagrams and application charts and specs. An original SM2029 did have more info it also than later copies. Just the electrical chapter in SM2000 would answer lots of common questions seen on here a lot but other than that the cost now may or may not be justified? Does it show how to overhaul your 2 cyld. engine, governor, trans, axles... ??? Nope.
Glen in TX
06-30-2006 18:44:35
 Re: Beware of Mis-Identied Service Manuals in reply to Glen in TX, 06-28-2006 22:27:56
To summarize the SM2000 was a shop manual for JD mechanics in the 40s & 50s when these tractors were new. For todays JD restoration mechanic obtaining the JD service manuals is good but if you want info for restoring that tractor today that has sat for years and years get a copy of Pat's restoration manual and a I&T shop manual.
