214T Something is NOTright PLEASE HELP
CPO
06-28-2006 10:37:16
I have a 214T baler that i really ahve had good luck with, until last night. I was baling along and the flywheel pin sheared. I replaced the pin and i checked the bale chamber to find that there was no slug, but the plunger had made contact with the safety catch that pops up when the needles are entering the bale chamber. My investigaton led me to find out that the baker was in knotting mode and that is why the needles were on the way up. is there a shearbolt or something that may have broke in the knotter shaft? As i rotate the flywheel through its stroke (It will only rotate until it hits the safety dogs)shouldn't the knooter finish so the safety dogs go back down?
johns48b
06-28-2006 13:48:10
 Re: 214T Something is NOTright PLEASE HELP in reply to CPO, 06-28-2006 10:37:16
if you hit a bad bump and jarred the neddles down the brake that holds them up is to loose. you may have to hold the neddles back by hand and let somebody turn the flywheel over by hand until it goes through it's cycle. i'd engage the clutch real slow and don't engage it fully until it turns over a couple of times. keep the engine idled down real slow too.
Walter Squires
06-28-2006 13:19:16
Make sure your needle brake is holding the needles in home postion.
ohio
06-28-2006 12:24:02
out of time. refer to owners manual, or have your dealer print out some lit.
mjbrown
06-28-2006 11:04:08
Pull the needles back by hand and see if that pulls the pawl (?) back away from the plunger crank. You will need to get out the book and follow the power flow back to the knotter and check for broken chains and timing.
