48 A Steering Gear
almrm
06-28-2006 07:15:15
I just completed a restoration on my 48 A, 609540. My father owned it from new as the primary motive of power on his dairy farm until 1980. It caught on fire with a full load of fuel in 2001. I rebuild everything except the transmission which was in excellent condition. Everything works fine and it started on the second roll over.
Now the question: I renewed everything possible in the steering gear and front pedestal. The shaft and pedestal casting looked great. Every similar tractor I have seen has the steering gear packed with grease. The restoration guides I have also show grease. By my manuals the origional intent was for gear lube in the steering gear housing. I used gear lube and it leaks very slowly. I intend to go back to grease. Has anyone been successful in sealing the steering gear well enough to hold gear lube without spotting the floor?
Thanks
Mike M
06-28-2006 07:46:30
 Re: 48 A Steering Gear in reply to almrm, 06-28-2006 07:15:15
Use corn head grease from Deere. I hear this grease will flow around some unlike reg. grease that gets hard and gets pushed out of the way and then you really have no lube.
almrm
06-28-2006 08:09:47
 Re: 48 A Steering Gear in reply to Mike M, 06-28-2006 07:46:30
Thanks for the tip. I will try it. I was considering cold temperature snowmobile grease or a synthetic for the same reason to aviod ending up with grease everywhere except where it is needed.
