2010 control valve
bowen
06-27-2006 13:14:20
I need to replace the control valve on my 2010, but I am not sure of what i am looking for in a replacement valve other than i want a cheap one(like cross) . It has a gressen valve on it now, dont know the #. Is it correct that the 2010 has an open center operation? Also with a new valve that has an internal relief can i bypass the oil outlet block that is used as a relief? any help would be great i dont know much about hydraulics,even a part # would be useful,thanks.
Bob
06-27-2006 16:27:31
 Re: 2010 control valve in reply to bowen, 06-27-2006 13:14:20
Yes, the 2010 is open center.
Are you replacing the original control valve, located inside the steering/control pedestal, or are you replacing an added-on valve, for a loader, or other attachment?
If you intend to replace the original valve, I think there is more involved there than you may realize, such as a sort of "power beyond" function, to feed the 3-point hitch (if used).
