52 b jumps out of gear
Crude K
06-27-2006 13:00:34
Dads 52b jumps out of second gear when he mows the pasture with a brush mower. He said in order to get it to move again he puts it in reverse and then back in second. He said now he can't get it into 3rd or 5th gear. Any help with an easy fix would be appreciated. He is 72yrs old and 60 miles away. I can go up and fix it if I know what might be wrong. Thanks for any and all help.
John
Chrisfromsolitude
06-27-2006 15:59:09
 Re: 52 b jumps out of gear in reply to Crude K, 06-27-2006 13:00:34
May check to see that your detents are adjusted right too.
buckeye al
06-27-2006 14:34:23
If the gear shift lever proper does NOT return to the neutral position, you probably have a broken shifter. If broken, the detent is no longer helping to keep the sliding gear from walking back out of mesh with the counter shaft 2nd gear. If it was just a bad detent or broken detent spring, the shifter lever would walk WITH the gear & he would not have to use reverse to "reset" everything. He'd need only to shift back into 2nd.
The need to shift to reverse may be "realigining" the shifters by bumping the second 5th sliding gear back where it ought to be!
I would be taking the shifter quadrant pedestal off of the tractor & have a look see. Sometimes it's just adjustments, sometimes not.
One helpful hint..... on these B's I find it a lot easier to put back together if it's in 4th gear than if in any other! That includes neutral. In 4th on the late B the lever is straight up and down so it goes together real smooth.
Good luck.
