720D Pony
Chatermb
06-27-2006 12:17:50
I was looking over the pony engine on the 720D I am working on. There was a comment in a past post about making sure the oil ports are open and the valves geting oil. I took a valve cover off and there is oil on the valve train.I read over the service manual but there was no mention of where oil is fed into the heads. Where does the oil come in?
720Deere
06-27-2006 13:09:23
 Re: 720D Pony in reply to Chatermb, 06-27-2006 12:17:50
It's not where it comes in that is a concern, it's where it drains back to the block that becomes clogged and backs things up. The drain holes are small and clog easily over time. Clogged drains are way up on the list of probable causes for a smoking pony.
If I remember correctly, the holes are located on the right side of the head as you face the spark plugs. Very small hole about 3/16" at the most.
Chatermb
06-27-2006 13:59:38
 Re: 720D Pony in reply to 720Deere, 06-27-2006 13:09:23
Thanks for your help.
There appears to be a drain hole in the bottom corner of teh area covered by the valve cover. It is hard to see it but the holes appear to be clear.
buickanddeere
06-27-2006 20:31:30
 Re: 720D Pony in reply to Chatermb, 06-27-2006 13:59:38
Two holes per head but only one matching drain hole in the block.
