CLUTCH REMOVAL MODEL A JD 1949
the junkman
06-27-2006 08:57:11
model A 1949. How do you get the clutch drum off? Do you just remove the center bolt and use a puller to pull the whole assemble off as one-meaning the clutch drum and internal plate as one?
Jim Benson
06-27-2006 13:02:46
 Re: CLUTCH REMOVAL MODEL A JD 1949 in reply to the junkman, 06-27-2006 08:57:11
Are you talking about the pulley itself or the driver? The pulley comes off by removing the innards and then the fork from the front of the transmission case where the pulley brake hinges.
Ben.So.Tex.
06-27-2006 10:57:45
You can remove it with 2 3/4 inch square nuts that slip in the slots of the counter balance, then screw the two bolts down evenly with equal pressure, tap the end of the crank shaft lightly and it should pop right off, and then you can remove the drum Do Not bugger up your treads on the crank, Please note that the counter balance HAS to go back on the same splines it came off of or your tractor engine will be out of blance and it WILL shake like leaves on a tree. Your crank shaft may a V mark on it that matches with a V mark on the counter balance. Good Luck
Jason Mills
06-27-2006 09:12:46
The drum will have to be pulled off after removing the retaining bolt and washer. We made one using a small bottle jack, some long 5/8" or 3/4" bolts and a piece of flat stock with the holes drilled to match the drum. Placing the jack between the flat stock and the crankshaft usually works for us. Most bottle jacks will work on their side if the pump part is rotated down. Good luck, Jason.
