JD 530 - Too Much Oil Came Out
Lee Schwebs
06-27-2006 08:40:55
Yesterday I planned to change the fluids in the 530. I removed the drain plug for the first reduction gear and got called away. Since I had a good sized pan under it, I wasn't worried about a quart of oil. I didn't get back to the tractor until this morning and found the pan overflowing with a mess around the tractor.
Can the transmission oil drain through the reduction gear and I goofed by not draining the transmission first? Or do I have a big problem?
Thanks for your wisdom - Lee
Glen in TX
06-27-2006 12:04:05
 Re: JD 530 - Too Much Oil Came Out in reply to Lee Schwebs, 06-27-2006 08:40:55
Like said the chambers are connected. The small plug was just for draining off condensed water out of the reduction gear cover or excess after other oil has been drained. Did water come out first? Pull the trans plug too and see if you get any water out first or milky stuff and if so change the oil. If the trans plug on other side showed it was overfull before you started draining it could be water or a leak from engine oil seal also if engine oil was going down.
machinery-man
06-27-2006 09:25:33
the chambers are all connected but the small drain hole use would be too time consuming to wait for oil to drain from. The small plug is just for what"s left after draining the main chambers.
Ray
06-27-2006 14:35:51
 Re: JD 530 - Too Much Oil Came Out in reply to machinery-man, 06-27-2006 09:25:33
The book shows a seperate compartment for the first reduction cover that only holds a quart,that's all i ever got out of mine.
