Holes in 44 B Maincase?
CalJim
06-26-2006 22:57:06
Had to split maincase from axle housing on my 44 B. The gasket had failed and was leaking 90 wt. all over the drawbar, the shop floor, etc.
Anyway, while putting the brake assemblies back into the maincase I noticed small holes directly above the brake shafts, one on each side. THEN I noticed two more holes directly underneath the first two. They are about 1/4" round, not drilled but casted in. These are not visible with the platform on. Can anyone help on this one? Thanks CalJim
Mike M
06-27-2006 04:55:00
 Re: Holes in 44 B Maincase? in reply to CalJim, 06-26-2006 22:57:06
I think those holes were to get the drill bit in as to drill the oil return passage down at the bottom of the brake hole. I usually put a dab of silicone on the top of hole to seal out the elements.
Kurt_JDB
06-27-2006 04:54:37
Caljim,
I have these same holes on my "51 B. The bottom hole is connected by an intersecting drilled passage to the main case. It also lines up with a hole in the brake assembly when installed. I believe it acts as an oil drain for the brake assembly shaft bushing area so that oil will not make its way into the drum/shoe area.
Although you say the holes on your tractor main case are are cast in, the ones on my tractor are clearly drilled. I believe the top hole is simply there as a way to drill the bottom hole, which would otherwise be inaccessible to a drill.
Good luck on the main case gasket fix. I am getting ready to fit my tractor back together this weekend after rebuilding the transmission and replacing a leaking main case to axle assembly gasket also.
Kurt
