Bent pedestal shaft on 45 B ??
wddave
06-26-2006 20:02:35
The sector gear had a broken tooth and the eccentric bushing was worn and cracked. Replaced these with good parts. Now shaft binds in the eccentric bushing. Back lash can be set so that it is OK turned one direction and it will be quite loose the other direction. Seems like the splined end of shaft must have bent when the gear tooth was broken. Seem possible?
DP
06-27-2006 13:29:21
 Re: Bent pedestal shaft on 45 B ?? in reply to wddave, 06-26-2006 20:02:35
Its very possible that the teeth in the center where it runs most of the time are are worn more then the rest. If you set the center part so its right, the ends will fit tight. Just a thought, as I've been through that.
Mike M
06-27-2006 05:06:20
Anything is possible ! You might be able to set it in some V blocks and check it if you pull it out again. Or take it to a local machine shop and have it checked.
