JD 3020 3pth.
fd33
06-26-2006 19:57:28
I have a jd 3020d when turned off the 3 pth. drops, why is this, and can it be fixed.
Tx Jim
06-27-2006 04:13:35
 Re: JD 3020 3pth. in reply to fd33, 06-26-2006 19:57:28
I agree with msb and it also could be leaky thermal relief valve or rockshaft control valves. Tx Jim
msb
06-26-2006 20:11:34
Probably a bad o-ring on the piston.No big deal to replace.Remove the small line going to the cylinder below and behind the seat.Takes an 11/16" open end wrench or of a line wrench would be better to use. Then remove the 4 cap screws holding the piston cover in place.Takes a 3/4" wrench.remove the cover.Raise one of the 3 pt arms up by hand while pushing the piston all the way in.Slam the arm down and the piston should come out far enough that you can ge a hold of it.Pull the piston out and inspect the o-ring for bad spots.Also inspect the bore for scoring.Replace the o-ring and back up washer.Reinstall everything and you a certified John Deere mechanic.
