420 puzzle
jd420pf
06-26-2006 13:32:56
my 420 will start and run for 30 seconds and quit. Twice in the past week I have got it running for 4 minutes at full throttle and If I tried to back it off it quit.
The carb was rebuilt two weeks ago and yes this is the problem before it was rebuilt. Also there is a new bowl and screen and I do have a steady stream of gas through the line and through the carb.
Another peice of the puzzle! I have switched out plugs three times H12, H10, & 216. All three plugs are dry black which means to much fuel in the chamber. Any ideas????? I'm STUCK
billde
07-01-2006 06:47:45
 Re: 420 puzzle in reply to jd420pf, 06-26-2006 13:32:56
You say you get gas to the carb, but are you getting gas through the carb. Is your float set properly?
Repost this topic, had a hard time finding it to reply.
Henry M
06-26-2006 19:14:54
How soon after it quits can it be reatasrted.
If it takes a little while, it should be checked for spart immediately after it dies and if it will not restart at that time.
billde
06-26-2006 18:27:26
bypass the air cleaner by disconnecting the air hose, you may have a restriction in the air cleaner. are the throttle plate and choke plate reinstalled correctly? Is the choke opening and closing properly? Check them while you have the air cleaner hose off. Don't overlook the possibilty that you could have a bad condenser. New doesn't always mean good.
Keep us posted.
pf420jd
06-30-2006 04:35:45
 Re: 420 puzzle in reply to billde, 06-26-2006 18:27:26
I changed the condenser, plugs and put a new battery on. The tractor fired right off and ran with the choke at 1/4 for about 3 minutes. and the stopped. I then removed the hose from the air cleaner and tried to restart. It started several times and ran for a couple of minutes and quit. It almost feels like it running out of gas but I know there is a good gas flow to the
carb. I can't help but feel my problem is something simple but I can't figure it out.
Any other suggestions? Thanks for you help
