1992 John Deere 544E forklift
Rick in Iraq
06-26-2006 00:46:52
I hope someone can help me out. I have been staring at this thing for a few days. The secondary steering pump is ALWAYS on. I have checked the pressure switch, secondary steering controller, the logic module, and they are all good if anyone could help me out and point me in a good direction I would appreciate it. Thanks!
Jonathan in MA
06-26-2006 09:04:14
 Re: 1992 John Deere 544E forklift in reply to Rick in Iraq, 06-26-2006 00:46:52
Sounds like you have to get in there with a test light. Not sure how the pump motor is wired up but they are usually similar in size to a starter motor. They usually need a lot of current to operate so there is usually a large solenoid that supplies a power connection... check if thats wired correctly/stuck "on"...Compare voltage at various points from the unit that operates correctly and the one that stays engaged all the time. Back track all and recheck all the connections that were disrupted when u changed the motor. Sounds like something got grounded on a solenoid that shouldnt be... or something small that was overlooked during the swap.. If the new pump has a solenoid attached, then maybe the new part is faulty.
Rick in Iraq
06-26-2006 23:51:42
 Re: 1992 John Deere 544E forklift in reply to Jonathan in MA, 06-26-2006 09:04:14
Well another problem with that is I disconnected the solenoid on the side of the electric motor COMPLETELY and the pump is still whining! Could it be running off straight pressure? Thanks for the reply!
Rick in Iraq
06-26-2006 02:03:51
Oh yeah just a little insight. Everything was working fine except the secondary steering pump was leaking a little so we replaced that pump and now I am at my current problem! Everything is wired up correctly. I had another forklift in the shop that I used as a model to wire it back up making sure it was wired up correctly!!! Thanks again!
