10A Mill (Hammer Mill)
Wayne in WI
06-25-2006 21:21:02
I recently purchased a JD stationary, belt driven, hammer mill. The tag simply says "10A Mill 42350". I wasn't sure it was John Deere, but 2 of the castings say JD. It appears to have been painted red with the hopper being green. A friend tells me that Montgomery Wards made this 10 inch and also a 15 inch mill for John Deere.
Can anyone tell me if this is correct, about when it was made, or anything else about it? THANKS
Vacherie
06-26-2006 12:16:57
 Re: 10A Mill (Hammer Mill) in reply to Wayne in WI, 06-25-2006 21:21:02
I have 10A mill. Where is the tag located? I couldn't find a tag on mine, only painterd 10A.
Wayne in WI
06-26-2006 22:19:08
 Re: 10A Mill (Hammer Mill) in reply to Vacherie, 06-26-2006 12:16:57
The tag on my mill is located on the end of the mill, below the hopper you shovel into. The tag is held on with 2 of the bolts in the mill. The tag is about 3/4 inch wide and about 4 inches long. It does not say JD on it. It only says 10A Mill 42350. What color is your mill? Mine is all red except the hopper. The hopper is galvanized sheet metal that was painted green. I don't know if the red is correct or if the mill was repainted at some time.
Glen in TX
06-26-2006 08:09:30
The marking "JD" and JD part #s you will find on castings tells you it was made by JD. You can still get operators manual and parts catalog for the hammer mills from JD publications. I still have some hammer mill manuals in my collection but not sure if extras for the 10A. I think it was the smallest one they made for tractors and you could belt it to a B or H with over running pulley.
Wayne in WI
06-26-2006 22:22:41
 Re: 10A Mill (Hammer Mill) in reply to Glen in TX, 06-26-2006 08:09:30
Thanks for the info. Would you happen to have an extra 10A manual you would consider selling? It would help me out with a little more information. Thank you.
jd40an
06-26-2006 05:17:44
I'm sure John Deere manufactured this mill themselves. I used one to grind hog feed for many years,& it was a very good mill, though a 14" JD worked better. A couple other companies built mills for Montgomery Ward, but I can't remember who they were. The one that had a travelling feed table was supposed to work well. I had an MW of the other style with gravity feed. It was about wothhless, compared to the JD.
mike in louisiana
06-26-2006 04:17:06
Wayne, I don't know if JD made any mills for Sears but David Bradley did. Mike
