JD 3010 Top Link Aftermarket
GnRPaint
06-25-2006 14:51:53
Hey everyone;
Recently purchased a 3010 which had no top link. I am looking for a good aftermarket one that will fit this tractor. I am not restoring this tractor, it will be used on the farm. I have seen refurbished ones for 200.00 that would match the original, yet I have seen aftermarket ones for under $100.
If anyone could point me in the direction of a good one to fit - I would appreciate it.
Also, can anyone give me the specs on fluids for the tractor (oil, antifreeze, etc...). I want to drain all and replace. I don't have the manual as of yet.
Thanks
Jason
Glen in TX
06-26-2006 08:31:08
 Re: JD 3010 Top Link Aftermarket in reply to GnRPaint, 06-25-2006 14:51:53
The aftermarket top link look alike runs about $170 to $195 that many of us sell and YT probably sells it right on here. Can also price aftermarket ones from aiproducts.com and JD parts catalog online. You can buy the top link pieces seperate also to repair a bent end on a original one.
Capacities for JD 3010 row crop utility diesel: fuel tank = 29 gals.
crankcase = 8 qts.
hyd. system = 9 1/2 gals.
air cleaner = 2 qts.
cooling system = 16 qts.
belt pulley = 2 1/2 pts.
woodbutcher
06-26-2006 04:16:43
Pete,
In my 3010 I always use John Deere Hygard in the hydraulics. Some say you can get away with the cheaper fluids, but I"d rather not risk deterioration of clutch and brake parts and stopped up screens because of the use of it.
I use 30 weight detergent oil. The chart in my manual is the same one most manuals use to show the lighter weight oils for use in colder climates. There are no specs for antifreeze. I"ve read that it"s best to change it every two years to prevent cavitation of the piston sleeves.
Butch
Pete/ME
06-26-2006 02:30:23
Paid under $30 for an import top link, JD wanted +$200. This for a 2240. Probably cheaper steel otherwise looks O.K.
