4010D Steering Problem
gordon smith
06-25-2006 07:19:13
I have a 61 (#11022) 4010D with steering trouble. Last year while planting corn the power steering on my 4010 started acting up, binding when turning left. I bought a rebuilt assembly out of midwest and installed it. It was a newer style and I plumbed it up correctly also installing a bleed back line to the reservoir. It didn't work, still binding up. Sent the tractor to JD dealer who removed and rebuilt assembly, telling me it was out of a newer tractor. The steering worked fine haying the rest of the year (no real use of 3point or SCV). I planted corn again this spring, no problems. I put on the saddle tanks and 6 row 3pt. knife setup to sidedress corn and in about 8 hours, the binding is back. Took the rig off and the tractor is sitting waiting to go back to the dealer with the same problem it had less than 100 hours ago. When the dealer rebuilt the box last summer he told me the mechanic found steel particles in the box didn't know from where. The hyd. filter looked clean and the oil also, it was changed twice while this was going on. The brakes are good, the tranny is tight with really good syncros. It seems when you begin to use the hitch or possibly the SCV this problem surfaces. I want to fix this problem this time for good. I know this is an old tractor but is in real nice shape powertrain wise, nice paint and rubber, 12V alt, and differential was updated to 30 series about 15 years ago. I only grow 200 acres of corn with 6 row equip. so it's not like it's being worked to death. I asked my dealer if it could be the supply pump in the tranny or some other Hyd. pressure problem and he didn't know. I've owned the tractor for 22 years and don't want to get rid of it because of this problem. Can anyone help out on this one?
donmyeil
06-25-2006 08:43:40
 Re: 4010D Steering Problem in reply to gordon smith, 06-25-2006 07:19:13
You need to rebuild the steering motor.
