1520 hydraulic problem
Pipestem
06-24-2006 18:53:32
My neighbor spent this spring rebuilding his 1971 JD 1520. He replaced the front hydraulic pump with a new unit which worked everything fine for a few minutes then the system just quit working. There seems to be fluid everywhere in the system and fluid comes out when you loosen a connection. Is there something special that needs to be done to bleed the system? Any help or insight any one might have would be appreciated.
cannonball
06-25-2006 05:39:55
 Re: 1520 hydraulic problem in reply to Pipestem, 06-24-2006 18:53:32
the front pump cannot pump if transmission pump don't feed it..have you changed filter...have you cleaned screen...the trans pump pumps to filter, from filter it supplies possible a pto or high low, maybe a reverser..oils trans and pumps to front pump...so if front pump is not getting fluid it will not pump...check filter and screen you will lose all fluid when pulling screen..i catch mine in tub...the screen is behind a round plug with a 1/2 square hole in it..clean screen and put back in. have nice day may god bless this usa
Pipestem
06-25-2006 05:45:03
 Re: 1520 hydraulic problem in reply to cannonball, 06-25-2006 05:39:55
Thanks! I'll pass this along.
buickanddeere
06-25-2006 19:49:03
 Re: 1520 hydraulic problem in reply to Pipestem, 06-25-2006 05:45:03
Find out what kind of oil(s) has been used in the transmission or hydraulics.
