850 , 1010 0r 1020? Need pros cons
Nylon
06-23-2006 23:25:36
I need a smaller mower tractor with live power and Really like the 850 buttttt... that 850 is alot of money. The 1010 and 1020 are more affordable. Wondering what you guys who have owned them and worked on them think. I have a 460 farmall and a 4020 deere. I am guessing the 10's are heavier tractors. I know the 850s are pretty reliable. I think I recall the 2010s getting alot of bad press on these boards and am wondering if the 10's are similar or are better. Thanks,
John
Joe Padavano
06-25-2006 09:56:52
 Re: 850 , 1010 0r 1020? Need pros cons in reply to Nylon, 06-23-2006 23:25:36
Here's another vote for the 850. I've had one for seven years now and the little tractor is just unstoppable. There was a design change around S/N9000 that added the two-stage clutch (allowing you to keep the PTO spinning while stopping tractor motion). Mine is an early version that doesn't have this feature. Around the same time there was a change to the hydraulic system routing that changes how the remotes hook up. The tractor was available in 2WD or 4WD and uses a 23 HP (PTO) engine. As others have said, the 950 is basically the same tractor with a slightly larger engine and 27 HP. The 1050 is a 950 with a turbocharger that ups the output to 33 HP. Parts for all three are readily available from JD.
I'm not sure what you consider big dollars for the 850. I see them on ebay frequently for $3000 - $6000, depending on condition and hours. Obviously things like 4WD or the optional remote hydraulics and loader will increase the price. I paid $5000 for mine with 500 hours on it in 1999, but that price included a bushhog, finish mower, tiller, and post hole auger. I've since added the remote hydraulics (I did it using aftermarket parts, not the $1300 JD kit) and a used JD75 loader.
jturbo10
06-24-2006 11:43:11
Would not buy the 1010 for sure. I've had a JD 850 for two years. It is an 87 or 89 model and it had only 125 hrs on it when I bought it from an estate. It did not get heavy use or long hours. I have been very happy with it. Very easy to use and very stingy on diesel fuel. It has a two stage clutch with live pto but does not have power steering. Has excellent three point system and has been absolutely fun to use on my finishing mower and other odd jobs like spraying small fields, pulling wagons etc. I believe the 1020 is a heavier built tractor, especially in the tranny and rear end. I would not spend a lot of time lugging the 850 on a plow or disk harrow but the 1020 could handle those chores easily. For lighter operations, it is a fine machine that you just turn the key and off you go. I would consider a 950 or 1050 if you wanted a little more power. Good luck with your tractor, whatever you buy.
Nylon
06-24-2006 10:20:30
Thanks for the top notch info guys! Much appreciated. JDMaris that is great background info and hands on info that you cant get anywhere else.
Thanks Again,
John
jdemaris
06-24-2006 06:19:01
I agree with the other two posters. I can't imagine why a 100% Japanese tractor - i.e. the 850 is worth more than the 1020 though. We sold the 850s when they first came out from Yanmar Co. in Japan. They were crude by US standards, but very rugged and fuel efficient. First ones had no power steering or brakes - no live or independent PTO, and nothing on them was John Deere other then the paint. They did get improvements as time went on. In regard to parts availablity, it was and is not now - as good as it is for a Deere built tractor. We rarely ever had a serious problem with any Yanmar tractor - but when we did - getting uncommonly needed parts was a mess. Especially for some internal parts like gears and bearings. Most of the bearings are odd-ball by US standards and you're not going to match them up by standard bearing numbers. We had a 850 in the shop that waited for parts for three months - that was back around 1985. Also had the same experience with an Italian built Oliver tractor - built by Fiat. We waited six months for parts for that! I won't say much about the 1010 - it's been talked to death. They can be somewhat reliable - but never anywhere close to the tractor a 1020 (or yellow 300) is. An 850 is not a match for a 1020 either. Parts availability is still great, most have power steering and power brakes, closed center hydraulics (the 300 is better then the 1020), powerful, and very handy to use. They were also availble with options e.g. hydraulic high-low, hydraulic reverser, independent PTO, live PTO, ground driven PTO, etc. From what I've seen, including the new tractors - Deere has NEVER made anything better - if you include ease of use, reliability, fuel economy, parts availability, purchase price, and simplicity of design. The latter - i.e. simplicity of design, hardly exists anymore with US built (or sold) equipment. Also, keep in mind, the German built Manheim 820s and 830s are almost the same tractors as the 1020s. I know of a few in my area, the people have owned them since new, and love them. I've seen such tractors sell for considerably more than what the Japanese 850s bring.
machinery-man
06-24-2006 05:23:41
drive by the 850, speed by the 1010, and stop at the 1020.
Mike M
06-24-2006 05:21:58
I think ? those 850 models could come in live pto versions or not. The early ones didn't have it so try it and check it out first. I think the same applies for all those models it was an option.
The 1020 models and the 850 models are great ! The 1020 should be easier to get aftermarket and used parts for.
The 1010 like the 2010 I would just avoid. People seem to love them or hate them ? Alot of them still around so they may not be all bad,but personally I'm not going to chance it !
