35 B with a terrible backfire!
Lars109
06-23-2006 15:51:52
I brought my little guy's(10 years old) 1935 B JD home yesterday to get it ready for a parade next week. It started up and ran fine as usaual. I noticed that the carb looked real dirty and so I decided to give it a once over. I replaced the throttle shaft and disk, cleaned all the passages and I mean all of them, replace both the idle and load stems, and all new gaskets. Now it takes forever to get it started and when I finally do, she coughs and spits and has a backfire sooo load that I'm sure I lost hearing in my right ear! Could my manifold be cracked? If it is, why did it run so good before. I know, if it's not broke don't fix it. Any help with the prevention of further hearing loss would be much appreciated! Thanks in advance!
Mike M
06-23-2006 18:53:19
 Re: 35 B with a terrible backfire! in reply to Lars109, 06-23-2006 15:51:52
A too lean mixture or cessation of ignition can cause backfires. Since you just did the carb. try opening up the mixture screws some.
Lars109
06-23-2006 17:39:07
The bushings are nice and tight and plug wires were not changed. Thanks.
bill in western ny
06-23-2006 17:02:13
i bought an H that did the same thing,turns out the throttle shaft packings were shot.may not be the same problem in your case but it cant hurt to check for leakage.just my 2 cents worth.thanks, bill
bill in western ny
06-23-2006 16:59:34
Butch ( PA )
06-23-2006 16:02:35
When doing this work, did you happen to change the wires on the magneto? Just a simple guess.
